Question about Galaxy Radios DX-949 40-Channels Base CB Radio
Low modu DX959
Use as base, A-99 ant.
    Genius:
  • 1,212 Answers
Http://www.cbtricks.com/radios/galaxy/dx959_mosfet/index.htm
http://www.cbtricks.com/radios/galaxy/dx959/index.htm
Has links to pages to show you how the alignment is performed, plus a schematic if you need to trace the transmitter portion for faults..
Posted on Feb 25, 2012
Sound is lost and regain when mic button is pressed
i would assume you have wired it incorrectly or have tried another 4 pin mic such as an midland which are wire differently for the galaxy, ranger, connex, cobra an undien 4 pin mics. Galaxy Radios DX959 MOSFET Final Service Manual
Aug 01, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Low pwr on xmit,weak rec,swr alert lite on xmit swr 1:4-1 on ch 20
you have no power because your radio is not tuned to your antenna.You get a new radio and put junky coax and a decent antenna and you expect it to work right. Get 75 ft of rg-213 and you will see a change.
Jan 08, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
How do peak and tune my 4300 dxl
modulation cut r249 & r246 these are limiters no limiters loud modu this radio is the same board as the 3300 connex
am low power adj vr 13 high power L 32 L 33
Jan 28, 2011 | Connex 4800-DXL 480-Channels Base CB Radio
I have a Galaxy 99 and I just swapped companies and I now drive a Peterbilt 387. When I plugged my CB in it tripped the fuse. I replaced the fuse behind the glovebox and CB still doesn't work so I am...
The Galaxy DX959 radio requires 12volt DC power. There should be a plastic fuseholder in the power cable near the radio end. There are no fuses inside the radio.
Ascertain that the radio has been connected up with the positive and negative the correct way around before replacing the fuse. Do not bypass the fuseholder or use a fuse with a rating larger than the origianal fuse.
If you have connected the radio to 24volt truck power instead of 12volt power even once you will probably need to send the radio to a competent technician for repair or buy a new radio.
Dec 10, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy DX959
it can not be tuned to go high or low you need to add switches for that and then realign the radio.
Mar 08, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Galaxy Radios DX-949 40-Channels Base CB Radio Logo
110 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
