Question about Ricoh Aficio GX5050N Printer
WHAT IS ERROR 997/996 THAT KEEPS BLINKING ON THE RICOH AFICIO GX 5050N?
SOURCE: My Rico Aficio 200
A transfer roller current leak signal is detected.
· High voltage supply board defective
· Poor connection of the PCU
· Transfer roller damaged
Inspect the contacts of the image unit.
Posted on Sep 14, 2009
SOURCE: ricoh aficio 2022 error code sc542
I have a Aficio 551/700 and the display reads SC124 anyone have a suggestion on how to re-set this
Thanks
ES...ASD
Posted on Feb 08, 2008
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
newport74
  • 58 Answers
SOURCE: Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Posted on Feb 27, 2010
Rich Aficio GX e3300n ink smears on every print. I have cleaned and flushed heads. Still have the same problem.
Contact Ricoh and talk to the tech support guys. The print heads are shot. They might send you a replacement printer and have you return that one in exchange.
Oct 30, 2013 | Ricoh Aficio GX E3300N InkJet Printer
Ricoh gx3300n Blinks lights on start but fails to power
Your printer is fried but i bet you figured that out by now. You using Saw grass ink i bet. Well thanks to them you now have boat anchor. The ink destroys the printer. I got one 2.
Aug 25, 2012 | Ricoh Aficio GX E3300N InkJet Printer
Error 990 keeps blinking on machine
This is an error that has to do with the ink drying up on the maintenance unit. This cannot be fixed by the end user and must be fixed by Ricoh. Error 990 is a Ricoh defect in which the printer should qualify for replacement.
Feb 12, 2010 | Ricoh Aficio GX5050N Printer
I have a brand new Ricoh GX 3050sfn. When I cnonect it and turn power on, I get system error s001. What can I do?
The travel lock is on open the top and on the front left underside there is a switch push it back and it should work fine
Dec 20, 2009 | Ricoh Aficio GX3000 All-In-One Printer
I have same problem - if I find a solution I will post it
this is a problem caused by the gel that is not supplied anymore in the printer. certainly the waste ink collector behing the machine is full. by replacing it i solved the problem sometimes, sometimes it is more serious ans the sparepart of the supply must be replaced by crafted man.
hope it can help !
Aug 21, 2009 | Ricoh Aficio GX3050 GelSprinter
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio  GX5050N Printer Logo
430 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
