Question about LG Televison & Video
On my 47LG5000 The channels keep changing and won't stop at any of them as if the up button is stuck
  • 3 Answers
Pull your remote apart and give it a quick clean i use a baby wipe then dry it off before i put it back together that normally works it cleans all the years of dust out of it hope this helps
Posted on Feb 22, 2012
4 Suggested Answers
vinceisaac
  • 2432 Answers
SOURCE: My son is in Stanley
hi the problem with your tv is with in button key controller board, here are the ways on how are you going to fix the problem.
  • open the back cover of your tv with the use of philip screw driver to gain access the button controller.
  • remove the connector and then detached the controller board, spray the channel up/down button with a electronic contact cleaner to have good contact.
  • if the buttons are worn out you can replace only the buttons just buy at any electronics store, you can also buy or replace the whole button key controller if you want. there are sites in an internet which provide button key controller for tv like for example you can inquire here.
  • now after you replace with new button controller reinstall the connector fix it not to loose and then placed the back cover of the tv unit and screw it.
  • plug the power cord then turn on the unit. good luck i hope it will help you.
Posted on Jun 10, 2011
Testimonial: "Thank u so much. If this works it will save us so much money. I'm disabled and live on a very limited income. Thank u. Thank u. Thank u."
  • 517 Answers
SOURCE: I don't have a remote
Good day to you!!!
please tell me your universal remote model no.
The device type you'd like to set and
the manufacturer of the device type or
you can find it by clicking the link bellow:
http://universalremote.manualsonline.com/
thank you and please do not forget to testify and rate me when it helps you...
Posted on Jul 13, 2011
  • 1212 Answers
SOURCE: LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
Posted on Dec 31, 2011
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
Clavinova is stuck on piano only it won't change on any other button ...any ideas?
That button is probably stuck, dirty, keeping other buttons from changing it. It is a delicate operation but, if you can somehow open the unit and clean the switch under the button with some contact cleaner and free it up it will probably work. switches and buttons get dirty and corrode over time. Let me know you're outcome and we can troubleshoot further.
Mar 03, 2013 | Music
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Oct 29, 2012 | Dell W3707C 37 in. LCD Television
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My wii starts up fine..but once were at the main screen it won't allow u to select any of the channels not even if a games in it...u can glide the remote over the channels and it recognizes them, but...
hi there, it happened the same to me, i only changed the batteries and blew into the button to take away any possible dust in it, because the a button might has stopped working, did you try with a different remote?
Jul 15, 2012 | Nintendo Wii Console
What's your problem?Won't stop changing channels
there is every possibility that the channel (ch - and ch +) button on the TV is stuck. This can make the TV channels change by itself. This also applies to the remote control (if any).
Turn off the TV, use your thumb to flip through the channel (ch - and ch +) button on the TV. This will free the stuck button. Also, check the channel (ch - and ch +) buttons on the remove and make sure it is also not stuck in.
If the above doesn't solve the problem, then it means fault is from the control board inside the TV. It maybe defective or needs servicing.
The board controls the buttons on the TV and it can be found on the position of the channel (ch - and ch +) inside the TV.
Note that TV stores a lot of current. So if you want to disassemble the TV to check the board allow the current to discharge by remove the TV plug from the wall and wait for about 1 hour before attempting to disassemble the TV.
Let me know if you need more assistance...
Regards.
Sep 27, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
I lost my remote and can't change the channel on the control panel. It is on channel 02 and it won't change even when I hit the channel+ or channel- button.
Hello.
Your problem is stuck keys in your T.V. It usually just needs cleaning, BUT it is hard to clean, because you gonna have to open up the whole TV. I advice you just buy a new remote from JVC or just buy a "Universal Remote".
Jul 18, 2011 | JVC AV-32D305 32" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Televison & Video Logo
100 people viewed this question
