Question about HP Office Equipment & Supplies
HP photosmart all-in-one printer/scanner/copier b110A
It keeps saying paper jam but there is no paper in it to be jammed
    Top Expert:
  • HP Master
  • 1,575 Answers
Hi
Try disconnecting the printer completely from power and the PC.
Reboot the PC.
Clear any print queues.
Connect everything again and try printing now.
Hope it helps.
Posted on Feb 22, 2012
professor_sc
  • 180 Answers
SOURCE: could you please tell me
Clearing a paper jam from the rear door Follow the steps below to clear a paper jam through the rear door.
  1. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the unit. Figure 1: Removing the rear door c00652942.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  3. Replace the rear door. Gently push the door forward until it snaps into place.
  4. Press Cancel to continue the current job.
Clearing a paper jam from the front door
  1. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door c00652943.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the unit, more paper jams are likely to occur.
  3. Close the print cartridge door. Figure 3: Closing the print cartridge door c00652944.gif
  4. Press Start Copy Black or Start Copy Color to continue the current job.
Posted on Aug 07, 2008
  • 3422 Answers
SOURCE: I have an HP Photosmart
HI,
You can first try a hard reset by unplugging all the cords of your printer for 30min and then plug them back in.Let me know the result.
Posted on Sep 17, 2008
SOURCE: paper jam in Printer Moel
paper jamed on the printer. cleared it and we still cannot print. It comes up "out of paper" -- removed the paper and insterted again and it still comes up the same. How can I clear that.
Posted on Dec 09, 2008
  • 67 Answers
SOURCE: pAPER JAM WITH NO PAPER
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
Posted on May 05, 2009
  • 27 Answers
SOURCE: paper jam in my printer
the paper sensor may have went in the printer try doing unplugging everything and plugging it back in
Posted on Jun 29, 2009
Hp photosmart printer keeps saying paper jam
Use a flashlight to examine as much as possible of the papaer path. There may be bits of paper or paper debris lodged in some obscure corner
Sep 29, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
My hp photosmart c4780 won't align because is keeps saying that the alignment plot in the scanner is skewed
If you have had paper jam and not replaced the rear paper grey plastic retainer correctly or somehow it has become loosened the paper will twist on entry and the printing will be askew. Sometimes not loading paper. It will then also not align when replacing cartridge. Had this problem, took out the retainer that has two plastic points that should locate in the retaining holes and pushed it back. Paper jam, printouts and alignment was then fine. Took me months to figure out as it was printing, just not very straight
Jan 24, 2012 | Office Equipment & Supplies
I have a problem with my hp c4180 photosmart printer, it seems to keep saying paper jam when there no paper in it.i pulled the paper out the wrong end and we fix it and then after a while it comes up...
A switch where the paper is routed through the machine is stuck in the wrong position whether paper is jamming it or the switch just got stuck. By the way a switch could also mean a sensor being dirty and if that is the case clean it with a q-tip and alcohol.
Jan 23, 2010 | HP Photosmart 4180 All-in-One Printer
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
PAPER JAM WITH NO PAPER
May 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
Paper jam
Open the rear access door to look for paper.
Dec 23, 2008 | HP Photosmart C6280 Printer
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
