Hp hdx16 no power
Laptop doesnt power up and doesnt charge the batterie also no lights nothing
  • sarkis avedikian Mar 15, 2012
    i was using it suddenly the cpu fan began turning verry fast and then the laptop shut dawn and thats all folks hehe nothing its dead till today
    its not even charging the batterie i mean when i plug the charger the charging led doesnt com on even
  • 6,771 Answers
The power supply charger should be checked for correct voltage, If it's dead it will need to be replaced. Remove main battery first, now turn on! if no change, you will need a professional to assess.
Posted on Mar 16, 2012
SOURCE: hp power supply failiure
Ive worked on a friends G7000 series laptop, since it had the same symptoms you have with yours.
I tested it on my own(identical) working charger/PSU and still no charging.
After taking the motherboard out, i traced the fault to a short circuit FET (field effect transistor) with the PCB reference of PQ1, located right next to the connector for the DC power jack loom.(short from gate to source) The FET is made by Fairchild Semiconductors and its part number is FDS6675BZ. Being in the UK, i ordered the part from www.farnell.co.uk at a cost of 56pence. After changing this FET(which is there to control power) the laptop is working.
If you are not good with very intricate surface mount soldering, then i suggest you buy the component, take the motherboard out of the laptop(not too hard) and take them both down your local TV repair shop for them to check and change it(tell them the board reference PQ1).. shouldnt cost more than £20 or so been as they dont have to fault find.
Martin
martinkwashere at hotmail dot com
Posted on Mar 03, 2009
gvctts
  • 103 Answers
SOURCE: haw to boot dvd windows in my laptop hp hdx16
Dear user,
Please set the CD/DVD ROM as a first boot device in bios setup. then you will be able to boot from CD/DVD.
Please dont forget to RATE my answer
Posted on Sep 05, 2009
Jack_Dawson
  • 287 Answers
SOURCE: my hp pavillion dv1000 wont turn on
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Posted on Jan 02, 2010
  • 206 Answers
SOURCE: I have a HP 6730B Laptop, it won't power on, when
Check to make sure your RAM is properly seated in the slots.
Posted on Oct 15, 2010
Geekman
  • 32281 Answers
SOURCE: hi. My acer aspire 5735 doesnt turn on. I turned
When a computer does not boot up, but the battery is charging, it could be a CPU or RAM problem.
Re-seat the RAM modules, this will make sure it makes proper connection to the motherboard.
Next try removing the battery and power up the laptop with just the power adapter connected. If it boots up then insert the battery while it is powered up.
Posted on Oct 23, 2010
My Laptop does not turn on anymore... When i insert the ac adapter a the power light flash instantly and gone... but my laptop doesnt charge or turn on...:( i have tried replacing the adapter but...
Take the battery out and run directly from the ac adapter. If it works then the battery is blown up. But if nothing happens and there is no activity then motherboard fuses may have blown or worse the motherboard is faulty. Look for another laptop in that case.
Mar 16, 2015 | HP Compaq 2510p Notebook PC
Factory reset hp hdx16
How do i factory reset my hd hdx16-137ous premium notebook pc
Feb 28, 2014 | HP HDX16-1370us (NV032UA) PC Notebook
I have an HP HDx16 laptop that seems to run very hot. Is there a way to check this problem or increase the cooling capabilities
If you are notusing your laptop on a flat surface, it may be obstructing the cooling vents onthe bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust. A laptop fanassisted cooling pad may solve your problem
Jun 11, 2011 | HP HDX16-1160US PC Notebook
Hello, I recently changed out the motherboard on an HP HDX16-1160US. It booted up just fine, but the video is jumbled/jumping. Is there anything I can do to remedy this problem?
have you double checked your connections sometimes those ribbons dont go in wright even see if your video card is not loose to test this hook up a computer monitor...
Apr 15, 2011 | HP HDX16-1160US PC Notebook
Power button lights up for a second and goes out with nothing showing up on screen.
Try this immediate checkup. 1. Remove the battery from the laptop 2. Plug in the power plug to the laptop 3. Turn on the laptop 4. If the laptop will turn on properly, it means your problem is the battery. If not, Remove the power cable to the laptop. 5. Press ESC or F1 key for about 1-2 minutes. Hold on to the button while putting back the power cable and press the power button. 6. Release the ESC or F1 if the power comes up.
Mar 10, 2011 | HP Computers & Internet
I have an compaq presariov2000 laptop. the problem is battery not charging and the charging symbol is also in a hide and seek mood. I also try scan for hardware changes method but it won't work. plz help.
go to compaq's website, download the latest Bios Update, run the bios update while the power suply is connected on the laptop. after the update, the power adapter should be recognized by the laptop
Sep 07, 2010 | HP Compaq Presario V2000 Notebook
Try to turn Dell Inspiron 6000 laptop and nothing happens. No lights, no sounds, nothing. Power chord is good and has output voltage of 19.5.
remove battery and then insert power cord and power it up. if it powers, then insert battery while laptop is on. otherwise, if it doesnt, get the battery charged from else where and insert it just to confirm that the power supply unit isnt spoilt.
Regards
Feb 13, 2010 | Dell Inspiron 6000 Notebook
My acer doesnt power on at all i plugged it in to the charger and it wont charge power light doesnt even light up and i plugged it in with no battery and still nothing. any ideas on whats wrong with it?...
Check it by putting it on another Power Adapter. It sounds to me as if the Power Supply has failed... Thats the bit that supplies DC.. to the laptop, and charges the battery, they fail frequently. Take it to a PC store and ask them to test it with another supply. The Power Supply MUST be the same specs tho.
Jan 19, 2010 | Acer Extensa Laptop
CN5560 power problem
it doesnt need to battey with AC. it must be work. but you have problem with mainboard that doesnt let the power on. need to get service.
May 30, 2009 | AMD IC Power CN5560 Laptop
I have a crappy HP pavillion dv6000 laptop, after working fine on shutdown last night, i turned on this morning and it would not boot up. the lights on the volume bar lit up, flashed, and went off...thats...
It's acting like the juice is drained in the battery. Are you sure it's charged? Do you have a spare battery you can swap out?
Some of them come with two. I actually have the same series laptop (a Pavilion dv6258se, 6000 series), and they can be a little flaky.
I also had an issue where my HP power cable (that connects the laptop to the wall outlet) was faulty, and needed to be replaced, because it stopped charging the battery. I ended up purchasing a generic replacement power cable on eBay.
Jul 24, 2008 | Computers & Internet
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
