Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My washer intermittenly doesnt spin - not all water is pumped out
Wife tells me water drained but clother were not stuck to the sides. I ran the system and i watched it go through all of the cycles. Some water was left at the bottom. i ran a heavy spin and all of the water was pumped out. Maybe the light spin is the problem ??? The lid switch seems ok. i looked and the coupler is ok. some other fixes (on another site) mentioned a belt. I cant see a belt down below.
  • apace1984 Oct 28, 2008
    My whirlpool washer does the same exact thing. I've had a repairman out twice and it runs fine for him
    Sergeant:
    Champion:
  • 324 Answers
There is no belt, if the coupling was bad then it would not spin at all. Sounds like it could be a worn basket drive.
Posted on Nov 04, 2008
Washer wont spin
The safety latch could be worn or stuck, the lid not closing tight enough to disenage the safety lever
Apr 20, 2013 | Washing Machines
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Kenmore elite catalyst wont drain or spin
Did you ever find out what is wrong? This is exactly what has been going on with ours.
Mar 25, 2009 | Kenmore Washing Machines
Front end Washer not spinning
youll need to gain access to and clean out the drain pump assy, the most common issue is that the drain pump is clogged, cant drain water therefore cannot spin.
Dec 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Machine wont drain
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 25, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
