Question about Frigidaire Washing Machines
Not starting just going on pausing - Frigidaire Washing Machines
    Sergeant:
    Champion:
  • 250 Answers
Check to make sure the door close switch is activating I've seen where the pin cracks off and you have to push it in with a toothpick till you can replace the door lock unit
Posted on Feb 22, 2012
I put a 2002 4.7 dakota motor in a 2004 dakota. Cranks but will not start.
Ok NOW FOR SOMETHING YOUR LOCAL MECHANIC WILL NOT TELL YOU..... I'm going to instruct you how to read engine codes on a Chrysler product.... follow these steps Do not turn the key all the way back to off but also do not go to start ,
  • Turn the engine off, then turn the key ON, OFF, ON, OFF, ON without starting the engine.
  • The codes will begin to flash on the Check Engine light. The light will blink the number of the first digit, pause, and blink the number of the second digit.
  • All codes are 2 digit numbers.
  • The code 55 indicates the end of the messages.
  • As an example, a stored code of 23 would flash 2 times, pause, flash 3 times, pause, flash 5 times, pause, and flash 5 times.
***** NOTE SOME NEWER ACTUALLY SHOW NUMBERS IN THE ODOMETER AREA OR RADIO
  • go online for your YMM to find codes. Hope this helps
Dec 27, 2017 | Cars & Trucks
My front load affinity will not start, says pause
Hello friend, thank you for your post!
I see that your Frigidaire washer, FAFW3517KW, is constantly showing you pause, when you press start it flashes the pause again, and that the door lock light does not come on. You could be seeing a couple of different possible reasons this is happening such as your control panel, door lock assembly, or door switch. Since it could be any of the underlying issues I would recommend having a professional come out to the home and repair the washer. -Matt
Aug 02, 2014 | Frigidaire Affinity FAFW3517KW 3.5 Cu. Ft....
Ltf2140
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
Interherm Model mmhb-09oabhp-06 During cold and on windy days the main blower starts then pauses, starts again and pauses, starts again and pauses, then finally turns on and runs.
the motor is working hard on start-up. could be the capacitor is going bad I would start with the capacitor and if that doesn't fix it the motor is prolly going to have to be replaced.
Dec 07, 2009 | Intertherm P3RA-048K Air Conditioner
Kodak printer 3 in1 says its paused when i try to print from pc
Basically the problem is caused by the printer spooler which is a printer system file that was installed on windows XP
For this problem kindly try doing the ff:
  • click START then select RUN
  • Type net stop spooler
  • Type net start spooler
  • Then try printing
  • if problem still persist call 1800 421 6699
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How can I enter a soft (2 sec.) pause in a contact number on A766
1) From the Home screen, go to Start > Contacts
2) Select the desired phone number
3) Press the Menu soft key and select Edit.
4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
6) Use the keypad to enter any additional numbers if desired.
Tip: You can create pauses longer than two seconds by entering multiple pauses.
Aug 01, 2009 | Samsung Propel A767 Cell Phone
How to cancel pragram after wash has started
hold the start button in until disply shows programme cancelled - it'll come after programme paused just don't let go or it'll only pause
Dec 20, 2008 | Hoover AAA160 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
