Question about Mercury KVM800M Motherboard
Need graphics verson AGP verson 2.0 - Mercury KVM800M Motherboard
  • 32,281 Answers
You can download the video and device drivers from Mercury WEB supportsite, select your model motherboard to download :-http://www.mercury-pc.com/downloads.php
Posted on Feb 23, 2012
How to disable integrated intel extreme graphics 2 and install a geforce agp video card.
In the presence of AGP Graphics Card, the system automatically switches the video output to it. Hence, there is no need to disable Intel Graphics. Just add the AGP Card and connect the AGP Output to the monitor.
CreativeTECH
Dec 29, 2010 | HP Compaq d530 PC Desktop
Graphics not displaying
Which graphics are you currently using?
If you are using an AGP graphics card in the AGP slot try replacing it.
Make sure your monitor is not the problem. Test on another system.
If you are using the motherboards built in AGP graphices you can try resetting the bios. See page 1-21 section 1.9 in your manual. After which you will need to reset all settings within the bios. See page 2-20, section 2.4.3 Set bios, Primary graphics adapter.
Cheers!
Mike
Oct 03, 2009 | ASUS P5S800-VM Motherboard
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
Compatibility
Any AGP model geforce should work. The newest models offering agp are the 6XXX series. Just be careful as they come in both PCI-E and AGP models. You want AGP of course..
Dec 19, 2007 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
AGP
You can add an AGP Graphics card if an AGP slot (Not White) is provided on the motherboard not a connector just to clarify.
Dec 01, 2007 | AOpen ADD Card AGP Graphic Card
Compaq 510s sff. Graphics Card
Hi Mikey You need to go to your bios setting and change your graphic adaptor from PCI/.. to AGP 1- turn your computer off (Shut Down) 2- keep press and release "delete" key on your keyboard while turning your computer on untill you go to bios (normally blue screen) 3-find your desplay/graphic or anything that is related to graphic. 4- Change it to AGP Now it should work but if it didn't work: 1- Faulty Display (Monitor) 2- Not compatible graphic card(rearly) 3- loose or damaged cables 4- Damaged Motherboard please let me know of your progress Kind Regards
Oct 07, 2007 | Compaq EVO D5S SFF Refurbished Desktop...
Upgrade to graphics
your in luck you have 2 options 1.use a agp graphics card 2. use a pci graphics card depending on how much money you want to spend,personally i would use the agp but it's up to you.You have 1 agp slot and 3 pci slots,an agp slot is brown and smaller than the white pci slot.You can use a top of the line agp i would get a nvidia agp gforce 3 or better their 80 dollars and upward
Oct 06, 2007 | Computers & Internet
Mercury KVM800M Motherboard Logo
22 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
