Question about Simplex Kaba Ilco Unican 1000 keyless lock
Lost the df-59 key and need to change the combination
Need to change the combination to simplex kaba 1000 series lock - lost df-59 access key
  • Anonymous Mar 24, 2014
    I HAVE THE DF-59 KEY AND SPANNER WRENCH
  • 963 Answers
For $9 you can get the df-59 key and spanner wrench from this company:
http://www.ckilock.com/Mpage18.asp ,10th item down on page
C.K.I. Wholesale Lock Supply 1-800-445-5230
Their item number SMPBC201278
Hope this helps!
Posted on Feb 23, 2012
4 Suggested Answers
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: i need a kaba ilco
Forgot combo
Go to this page for starters (you can copy and paste it into your browser):
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
I don't know if you are dealing with the Model 1000, L1000, or LP 1000, but regardless, you'll see a grid for these various model on this page. The information you need is most probably under the rightmost column, TIPS. When you click on that you'll pop up a further choice of how to change or reset the combination.
You will find that you need a DF-59 key as part of the process. I believe a Df-59 key can be purchased at this site:
Jun 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Is there anybody to help me? It's urgent please...
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Good Luck!
Mar 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to find instructions to change combination on Kaba L 1000 keyless lock.
REMOVE THE KEY.
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
Good Luck!
Feb 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Could you please help me. Thanks.
I believe you can find this to be relevant:
REMOVE THE KEY.
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Feb 14, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lost code for 5 number lock
REMOVE THE KEY.
Good Luck!
Jan 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
We are trying to change our code for ILCO, Unican Corp. keyless lock, serial # 743660000, model # 201049 USA (think it is model #) It appears we have lost the default code, how do we find a default code. ...
1.) ENSURE THE DOOR IS OPEN! This is totally necessary to reset the combination!
REMOVE THE KEY.
Good Luck!
Jan 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need a instruction manual for programing of KABA lock. Model No. E-760 K
REMOVE THE KEY.
Good Luck!
Dec 22, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need to know how to reprogram the code on a Simplex Kaba IIco Unican 1000 keyless lock
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Good Luck!
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do you reset the combination?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
this site:
aspx?id=13
Good Luck!
Nov 29, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I NEED TO RESET THE SIMPLEX 5 BUTTON LOCK, BUT I DON'T REMEMBER THE CODE, HOW DO RESET IT???
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
this site:
aspx?id=13
Good Luck!
Nov 22, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
1,011 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
