Question about Casio TE-2000 PC Desktop
Turn off journal printer - Casio TE-2000 PC Desktop
How do I switch the journal feed off 4500 f
If you mean turn the journal printing off, you can't. It doesn't have a journal memory because it is designed to print everything on the journal roll. That is why you buy a two station printer model. It stops staff from covering transactions and the tax office will want to see your journal rolls if they audit you.
For those who asked about a programming manual for the Casio TE4500F, one of the users has it here:
https://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
May 09, 2015 | Casio TE-4500F Electronic Management Cash...
How do I print out a sent journal-specific dates
Dear
as i believe the model ML2955DW is only a single function duplex printer and no option for the ans. However in case of multifunction, press MENU key scroll to display REPORTS, press ENTER or OK, scroll to display PRINT JOURNAL(TX REPORT or SENT REPORT),press ENTER or OK.
Thanks.
Feb 24, 2015 | Samsung ML2955DW - ML-2955DW Wireless Mono...
How to print electric journal for sams4 ER-265
On the 265 you will need to enable this feature first in the program flag setup. Once enabled, print journal by turning key to X and pressing 300 CASH. Then to clear the electronic journal, turn key to Z and press 399 CASH
Mar 15, 2014 | Sharp XE-A402 Electronic Cash Register
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
What is the difference between Mac OS Extended and Mac OS Extended (Journaled)?
Mac OS Extended(Journaled) is just the same as the first but with journalling turned on.
Journalling is not exclusive to the Mac OS as there are also journalling options in other operating systems
Journalling is a failsafe system that keeps a record of each operation before it is performed so that it can be traced back once a crash occurs
Journalling adds additional overhead that can result in slower overall performance
The performance hit is not that significant to most people but might affect power users
Nov 11, 2010 | Computers & Internet
How to set perimeters to get confirmation on faxes
at the fax parameter ( F7-04) you may look for COMM JOURNAL.
inside COMM JOURNAL, you may choose what will it print. is it always, during error sending, or never print.
that's it :)
Jan 27, 2010 | Panasonic Workio DP-190 Multifunction...
DFX-9000 printing 2 Journals on 1 page instead of 1 per page
Have you tried to check the print settings?
Click on Start>Control Panel>Printers(Printers and faxes)> Right Click on the DFX-9000 printer icon>left click on properties>click the printing preferences button located below the properties box. In this window you should see the setting of the printer itself.
Sep 05, 2009 | Epson DFX-9000 Dot Matrix Printer
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
Journal receipt won't print.
Hi. The journal side should always print (right side of printer). There is no way to turn it off. If it is feeding the journal paper, but not printing, then you may have the roll in back to front (in the case of thermal printers). If it doesn't feed at all, then you may have a feed problem. In this case it will usually be printing over the same place on the roll continuously. Another thing to test is whether it prints on both rolls when printing Z reports.
If none of this helps, then please let me know the brand and model number, and I will try to suggest more checks.
Mark
Aug 30, 2008 | Casio Parts Cash Register PC Desktop
Casio TE-2000 PC Desktop Logo
67 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
