Question about Electrolux Vacuums
How do I change a fan belt?
Electrolux Z4730 upright vacuum cleaner
reddevil6
  • 1673 Answers
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
It should be a standard Eureka U belt. That number you have is not a good number. Most repair shops should have this one. The R belt is a real thin and different material.
Posted on Mar 11, 2008
SOURCE: Oreck Vacuum Cleaner problem (upright)
To jrican-80,
My new upright(NOT an Oreck) is over three years old and hasn't needed a new belt so far. Orecks clog very easily, and when you bring it in for repairs, or for the yearly "tuneup", what the store manager wants you to do is spend more money on the existing sweeper, new roller brush, for example. That's the reason for the yearly checkup, to BRING you back into the store so you can spend more to help Mr Oreck make more money.
Seems like you either have a connection to Oreck or simply think that an overpriced, cheaply built vacuum cleaner is actually a good machine.
Posted on Sep 16, 2008
ukvacfan
  • 328 Answers
SOURCE: How to change a belt
A very easy procedure!
Look at the front hood of the Purepower (where all the lettering is including the 1600 or whatever the model number and name is located at) and you'll see at the back two screws either side where the back wheels are. Unscrew these and then prise using your hand/fingers the floor selector dial knob off. Once that's done the hood will pop off and you can get into the roller brush and drive belt. Then simply lift out the roller brush and fit a new belt.
This method is for all Hoover Purepower models and DustManager uprights.
Posted on Sep 27, 2008
  • 389 Answers
SOURCE: changing the belt on a sebo upright vacuum cleaner
This machine has two toothed belts and it makes sense to change both while you're at it. Incidentally, this is a job you shouldn't have to do very often - Sebo belts usually last at least 10 years.
So, here's how to get at the belts and change them... NOTE - any use of the words LEFT and RIGHT assume that you are looking from the REAR of the machine.
STEP 1. Separate the base from the bag compartment: press the button at bottom front centre of bag compartment and lift bag compartment upwards away from base. Sometimes this is quite stiff and four hands would be useful, you can lever it from behind with something relatively soft (the plastic handle of a dishwash brush works well) but take care to lift vertically upwards, not sideways or you risk bending a metal lever that's hard to get back into shape again. Rest assured that once you've pressed that button there is nothing holding the two parts together other than friction!
STEP 2. Turn the base upside-down and undo the FOUR DEEPLY-RECESSED SCREWS. All the surface-mounted screws are irrelevant to this job.
STEP 3. Turn the complete base right-way up, release the foot pedal and move the vacuum tubes out of vertical. The top cover will then lift off. You will see there are two belts - the pulley device between the motor and the brush roller is the sensor that measures the drag on the brushes and operates the automatic height adjuster to maintain constant drag. To the right of that double pulley is the electronic circuit board - note that it has a sensor that locates within the pulley device, be careful not to damage it.
STEP 4. At the left end of the motor cover, the drive cog is concealed by a small cover. Lift this cover out vertically, noting how it locates in the frame for when you come to put it back. Next, although not essential, it helps to remove the metal lever because if it falls out when you're not looking you may later be uncertain about how to locate the small coil spring. So slide that lever out towards the motor, noting how the spring locates.
STEP 5. Undo the two screws holding the circuit board (take care the washers don't slip away). Then undo the four screws holding the double pulley. Once that's free, you'll be able to change the belts.
Re-assembly is simply the reverse of the above process.
If you need more help, just ask. Please remember to rate this response.
Posted on Feb 20, 2010
SOURCE: I have a 15 yr old electrolux genesis upright
Fip it upside down and hit the roller with a malett
http://evacuumstore.com/c-99-electrolux-belts.aspx?manufacturerfilterid=0
Posted on Apr 17, 2010
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
Problem with Electrolux Vacuum Cleaner, MDL EL8501A. Brush Roller will not turn
try pushing the reset button..its a little red usually located on the right side of the nozzle cover..
May 27, 2014 | Electrolux Versatility Bagless Upright...
I cannot find a replacement belt for my Electrolux versatility HEPA bagless upright vacuum cleaner. Model# EL8505B
You can try to get a belt directly from Electrolux or maybe a local vacuum cleaner repair shop
Aug 14, 2013 | Electrolux Vacuums
HOW TO TAKE APART THE electrolux el8502 vACUUM
go to the next web and proceed according:
http://www.ehow.com/how_4761328_change-belt-vacuum-cleaner.html
God bless you
May 09, 2012 | Electrolux EL8502 Versatility Bagless...
Electrolux regency series upright vacuum cleaner 1572e belt replacement
Hello see the video below for help otherwise for about 20 bucks take it to as local shop Changing belt on an Electrolux upright vacuum
Nov 26, 2011 | Electrolux Vacuums
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Electrolux aptitude upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=113651&thid=541998
Posted by inoubliable on Apr 24, 2008
My Electrolux is about 3 years old. Never had any problems with it until recently, it is LOUD. It doesn't seem to make a 'normal' running noise unless it butts up against a wall, furniture, etc. trying to vacuum is like being on a jet runway. Is something clogged? Does it just have issues from not being used for about a year? (Last house had no carpet).
It sounds to me that you have a broken fan, in every vacuum I have seen with the loud noise such as you described, it has been a broken fan or fan blade and is in need of replacement. You can try to do it yourself but I suggest going to your local vacuum cleaner dealer for service with the problem. Remember, a suggested belt change if the belt is flat would be 4 to 6 months and If you have a geared belt the belt change would be one year or better depending on wear factor. So, if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Electrolux EL5010A Bagged Upright Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
