Question about Canon FAXPHONE L80 Laser
Paper jam sending faxes
My Canon L80 receives faxes fine, but when I try to send a fax the sheet goes partially in on one side and then jams. Opened it up and everything looked normal, no paper clips or anything stuck in there. Is there a way to fix this? Called Canon and they told me that the nearest service center is over an hour away.
  • 318 Answers
It is the document stop arm that is broken.You can remove it.The machine will work without it.
Just make sure you remove the document stop arm and not one of the other sensor flags in the document feeder.
Posted on Oct 29, 2008
  • Ian  Auret
    Ian Auret Oct 30, 2008
    What you also can do -take a peace of tape and stick it onto the arm.The paper feed must be free to past this document stop.
    The tape must keep the arm in the uprigth possition.
    This will help
My fax machine is displaying "Clear Paper Jam" I have looked every where and can't see a piece of paper stuck in it. This is making me unable to recieve faxes but allows me to send them....
it is the paper jam sensor thats giving a false reading. It can b a very small piece of paper that u can easily remove with ur hand or by blowing. Open it, remove ink catridges, blow it thoroughly n make sure all sensors are clean of dirt. Also mke sure tht the paper u use is preheat to avoid these paper jams. Hpe it helps, pliz vote. Good luck.
Jun 08, 2011 | Canon FAXPHONE L80 Laser
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
I have Paper Jam Display on my Canon Super G3 Fax phone L80 FaxScreen.
There is most likely a piece of trapped paper where you cannot see it and it is covering a jam sensor. Try to cheat the machine by turning it off and remove all the printing paper. When you turn it on look down where you see the paper normally feeds and see if you can see any rollers turning. Then, try to take a sheet of paper and feed it through were the printing paper usually goes. Open up the cover where the cartridg goes as well and you may see the trapped paper move when you feed through your piece of paper. Remove the cartridge if necessary to get a good look and see if paper is trapped near.
Jul 08, 2009 | Canon FAXPHONE L80 Laser
Fax in receiving faxes but not printing them.
noavatar.png Incoming faxes automatically go into memory. We can't print them out. Would like incoming faxes to print out as they used to. have tried the on off button but it didn't fix the problem
Apr 16, 2009 | Canon FAX-JX200
Canon faxphone L170 won't copy
if you look at the top piece of paper in the cassette is there a smug mark or wrinkle in the paper. you my just need to clean the feed roller. ( black or gray roller ) . I'm not sher on this model if it is a rear paper feed or a cassette from under if it is a back feed one look in side the paper shoot of any fourn object is in there. Hope for the best.
Feb 02, 2009 | Canon FAXPHONE L80 Laser
My Canon Faxphone L80 Ptints a solid black page when we receive a fax in-it's is sending a fax correctly.
Hello sir; Try to make a copy on this machine, if copy coming out good that's means the problem happen on remoted side.
Jan 14, 2009 | Canon FAXPHONE L80 Laser
Fax says Paper Jam but there isn't one!
After what operation does the machine report the jam. If it is trying to print something and the paper doesn't pull, then it will report a paper jam, even though the paper didn't move. If this is the case then the paper feed tire behind the toner is dirty. Cleaned with rag and rubbing alcohol.
Apr 08, 2008 | Canon FAXPHONE L80 Laser
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Canon FAXPHONE L80 Laser Logo
146 people viewed this question
old marine
old marine
