Yahoo Messenger Logo
zain Posted on Feb 22, 2012
When I invite someone to my cam on yahoo, it says connecting. and it take s a very long time then it get back with server error
If I invite someone to my webcam, it says connecting only and nothign more...it takes for ever but dosn't work at all, also when friend invite me to view the webcam it says also connecting... but not works too... thei on yahoo and on msn too... skype is working fine.. on msn I see my cam insted of the other party cam on video calling .. whow can I solve this problem?
Stave Chiponda
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Feb 22, 2012
Stave Chiponda
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
1366
Points
9
Reconfigure you yahoo settings to identify the cam as its default
A network error occured while conecting to the server. i get this error evry time when i whant to invite someone to view my web cam. what is rong ?
Probably your firewall or network settings. Check that the program you are using is defined as an exception in the firewall, and see if any ports need to opened.
Here are more details: http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
1helpful
2answers
I cannot view other webcam in yahoo messenger, always not connected.
Webcam not Connected ( to your Messenger ) can usually be overcome by setting your Messenger Internet Connection
MESSENGER INTERNET CONNECTION
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'No proxies' or 'Connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes, If not change them > Apply > OK
2answers
My yahoo and webcam won't work together i keep getting an error message on yahoo, what do i do???
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to Yahoo Messenger.
COMPATIBILITY WITH YAHOO MESSENGER
Use Internet Explorer to visit this page to check compatibility and automatically download the latest webcam control
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamtest.html
CONFIGURE SOFTWARE
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
SET WEBCAM DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
IN USE
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( 1 minute) before they see you, so don't be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
Your contacts needs to configure their connection the same as above or they may get a "webcam not connected" message
I cannot broadcast myself.........alwys server busy
well i dont thing it s your cam you have to check and see if you get good internet conection update your messenger memory slow in your pc could olso a cause
2helpful
I cant access my yahoo mail? ERROR CODE 1
I think you might be able to use a mail program like windows mail or incredimail (free download) and then import your yahoo stuff, Yahoo is a pop server so you should be able to open windows mail create a new account and get the server information from yahoo support, I know the one will probably be pop.yahoo.com and the smtp server should be smtp.yahoo.com not too sure but give it a shot...Steve
Jun 13, 2009 • Yahoo Mail
Regarding my webcam
REDOWNLOAD THE LATEST VERSION OF YAHOO IM AND GOTO SETTINGS AND RESET-UP CAM/MIC.RICHARDM69
3answers
Logitech Webcam - Yahoo IM
hi!!!
that common cause of the web cam!!
so here your gonna do
try to re-install the driver of your web cam
Webcam connecting to server error
there as bin sever problems with yahoo this wont be down to the cam keep tryin the cam an yahoo should sort it out in tym
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
