Question about Hotpoint HSS25GFP Side by Side Refrigerator
NO WATER AT FRONT PANEL
CAN HEAR THE SWITCH ACTIVATE
  • Hotpoint Master
  • 4,655 Answers
It is possible that water still may not get through the=> WR57X10051 Water Valve - Dual Outlet Pull the refrigerator out from wall and examine the water valve by carefully unplugging power to refrigerator, removing lower cover and disconnect water line just before water line enters the water filter assembly if applicable. Carefully place the end of water line into a pan and plug refrigerator into power again. Press the dispense water button again and watch to see if water enters pan. If no water goes into pan replace the WR57X10051 Water Valve - Dual Outlet and if not then check the water filter by loosening the outer housing and then press the water dispenser to see if water pressure reaches water filter, Let me know your results Thanks Sea Breeze USER Manual Here
Posted on Feb 23, 2012
  • John Tripp
    John Tripp Feb 27, 2012
    Thank You Albert! John Tripp
  • Donnie Wright Apr 20, 2012
    I also have a problem getting water to dispense, The problem is the water line freezes in the door just below the ice dispenser, I have thawed it out several times but it freezes back up. A service tech told me the only way to fix it is to replace the freezer door. There is no way to get into it. My theory is that there is condensation in the door and it rapidly freezes back up. Any ideas as to how I can get it dried out?
    I have cut a sheet of 2 inch styrofoam to stick inthe door while it thaws out but refreezes overnight!
Followed the directions to adjust the water level dispensed. While having the switch on the panel on "set" I clicked the start button to remove the required 2 sec intervals I needed then held...
While holding down the switch you will hear the solenoid start and stop 3 times. You should have to hold down the switch for about 10 seconds to get the program started. Make sure the white lever on the board is not on the L.
Sep 20, 2011 | Bunn CWTF15-TC
The water is not coming in
Hello there:
There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve. it will look like this pict below
Nov 13, 2010 | Frigidaire ATF6000ES Front Load Washer
When i switch on the wsah i hear ticking but it wont start up or no water comes in
Your float switch isnt making contact. Red Stick (behind lower front panel ) must touch off both low water and full, or machine will not function.
Jun 03, 2010 | Siemens 24 in. SL34A006UC Built-in...
Tub over flows.water will not cut off
You need to check water level switch, how to do this is take front panel off, and blow in thin clear hose just to make sure the hose isn't block, if it is block just blow into it till you hear the click.. If you don't hear the click you need to replace the switch..
Jan 12, 2010 | Whirlpool Washing Machines
Ice maker won't fill with water
There is a soleniod near where the ice line hooks in, Take it off and clean it with hot water and soap, if that does not fix it it may be bad
Jul 31, 2009 | Frigidaire FRS26R4A Side by Side...
The water thing of the windshields is not working, I already tried putting a pin through the hole to see if it was clogged, and I checked the water thing at the front and its full. What else can I do?
have someone hold down the washer stalk to activate and listen, if its not spinning to squirt water then you may need a new pump, or the switch on the column.
Jul 16, 2009 | 2002 Kia Rio
Water does not drain
this sounds like the pump if you can hear a buzzing your pump is working if there is no buzzing your pump as gone they are not that hard to do 20 min job hope this helps
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Water not working but ice does - kitchen aid superba
When you activate the switch, do you hear the inlet valve buzzing? If you do, check the container or tubing in the fresh food side and make sure it is not frozen. If you do not hear the valve buzzing, chech the valve. If it appears to be ok, then you will need to check the switch inside the door control panel.
Please let me know if I can help further.
Thanks
Vic
May 20, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker works, but I can't get a drop from the water dispensor
If you are making ice then the chances are that the solenoid or the switch mechanism is bad on the water side. The water valve has two solenoids that control water flow. The icemaker side is control by the cam switch that rotates on cycling ice drops and the water side is controlled by the door switch which operates the water valve. If you hear the click when you activate the door switch, listen to see if you hear a clicking near the back of the refrigerater when you hit the switch. There is also a possibility that the water inlet screen is clogged with debris.
May 09, 2009 | GE GSS25SGMBS Side by Side Refrigerator
F10 FAULT CODE
F10 means that the pressure switch (water level switch) is not sensing the correct water level.
This can be for one of several reasons.
Firstly ,clean filter, if no filter at front behind bottom panel ,then remove lower rear panel, remove large black hose from bottom of tub, remove and clean filter inside..
Detach pressure switch hose attached to plastic chamber which comes from large black hose, this is a small plastic hose, blow down it , and you should hear the switch click if you listen carefully.
If you cannot hear it click, then switch is probably faulty, follow hose to switch.
Make sure the plastic chamber is not blocked where the hose is attached at bottom end.
Plz rate my solution.
Thanks.
Jan 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint HSS25GFP Side by Side Refrigerator Logo
936 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
