Question about Acer Computers & Internet
I have an acer aspire 5600 i turned it on yesterday and its saying windows system is either missing or corrupt :L it didnt come with any cd rom...so cant try to repair it....helllppp!!
  • Acer Master
  • 4,340 Answers
Check the D:\ drive, it may hold the system files. BEFORE you do anything, extract the HD, and remove your data from it, using another computer....unless you have a current backup.
Posted on Feb 22, 2012
3 Suggested Answers
techanurag
  • 101 Answers
SOURCE: I WANT TO INSTALL THE DRIVERS OF ACER ASPIRE 5600
hi friend,
if you required drivers for acer aspire56000 then follow the link and download all driver for your selectd operating system from:
http://support.acer-euro.com/drivers/notebook/as_5600.html
Posted on May 14, 2010
  • 1570 Answers
SOURCE: windows could not start, file
Hi !
If you enter in Windows XP set up, below instructions will appear:
1. To set up Windows XP not, press ENTER.
2. To repair Windows XP installation using windows console, press R.
3. To quit set up with installing Windows XP, press F3.
By pressing ENTER means it will repair your operating system and it will delete all your files in hard disk drive leaving nothing to that particular drive or partition.
By pressing R means it will repair your operating system files only and it will not remove your files.
By pressing F3, it will exit the Windows XP set up.
I hope this is helpful and thank you for using FixYa !
Posted on Jan 06, 2011
My acer one has no cd rom and has an error report windows could not start because the following file is missing or corrupt <window root>\system32\hal.dll please re-install copy of the above file
You need to repair your windows, with either using Recovery or get the external CD then reinstall operating system. Hal.dll usually still in your system32 folder but corrupted..
Aug 05, 2011 | Acer Aspire One PC Notebook
I have an Acer Aspire 5630 when i turn it on i get a black screen showing. PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM. Operating System not found I have got a...
The message is the laptops way of saying that it has looked for an operating system and could not find one. The PXE rom message refers to it trying to find a network boot record.
Test this by checking your Bios settings, in the boot order, see that the CDRom is set to 1st boot, then the second bot is the HDD, If the thing will not boot. Check you can see that the laptop "sees" the boot devices, if it does not, you have a problem, as it looks like the controllers are damaged.
If it Does find the boot devices, but it still defaults to a network boot, there is either NO OS on the hard drive, or it has been corrupted.
Use the Vista DVD to re-install Windows (you may be lucky enough to get away with a repair installation), after you have reinstalled windows, the drivers etc can be found on Acer's site quite easily
Jun 19, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
Netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using...
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
Oct 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Laptop is saying file missing/corrupt
You can do it without using the cd, but you'll need another PC which is running properly with the same operating system. What you need to do is just copy the particular missing file and paste it in your hardrive windows system32 directory using command prompt, or you can connect your hardisk to another pc and copy/paste it.. Good luck..
May 12, 2010 | Acer Aspire 3610 Notebook
Get an error message that windows would not start missin or corrupt windows\system32\config\system
you can use system restore to solve this problem .
try to restore your system to an earlier working restore point.
this will fix your problem.
Apr 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
\Windows\System32\Config\System; Repair w/CD-ROM; NO CD-ROM
if you can get an external cd/dvd drive from a friend, then you could solve the problem.
other solutions would mean that you will reinstall windows again. This takes more time and has a few tricks to be done from a flash drive.
Mar 22, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
