Question about Cisco Computers & Internet
Cisco ip phone 7942 shows upgrade and hung there
Cisco ip phone 7942 keeps showing upgrade and rebooting
fcollingwood
  • 58 Answers
SOURCE: Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Posted on Mar 21, 2008
manoline
  • 52 Answers
SOURCE: cit300 ip phone problem installation
Make sure to use the driver for Vista here
* Just look for CIT300 and download the 32bit driver.
* Make sure to uninstall the previous installation you did.
* Unzip the download file
* Run the setup_web CIT300.exe file and just follow the installation instructions.
Hope this helps! Goodluck!
Posted on Nov 09, 2008
ward_knutson
  • 64 Answers
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
Posted on Nov 25, 2008
  • 33 Answers
SOURCE: Blank Screen
Try changing the connection on the ethernet switch like the cisco switch if you are you using power on ethernet...
Posted on Dec 11, 2008
RPaterson
  • 48 Answers
SOURCE: Cisco 7911G definitely dead?
You are very close to fixing your problem. You will need the correct firmware and files; these are proprietary but you should be able to acquire them from your certified reseller. Alternatively, here at IdacomUSA, we have the proper firmware on hand, and can flash the phone for you to get it back to life. Call us at 1-800-903-9190 or visit us at http://idacomusa.com
Posted on Feb 11, 2010
Cisco 7942 factory reset
When performing the factory reset procedure we are about to describe, it is important to keep in mind that the IP phone will lose all configuration files and phone applications. This means that it is necessary to have CallManager or CallManager Express setup so that the IP phone will be able to receive the new information (phone application and configuration) after the reset procedure is complete, otherwise it is most likely that the IP phone will not be usable until this information is loaded on to it.
This preparation also happens to be the procedure for upgrading a Cisco IP phone firmware.
Follow the steps below to successfully factory reset your Cisco 7942, 7962 IP phone:
  1. Unplug the power cable from the phone and then plug it back in. The phone begins its power up cycle.
  2. While the phone is powering up, and before the Speaker button flashes on and off, press and hold #. Continue to hold # until each line button flashes on and off in sequence in amber.
  3. Release # and press 123456789*0#.
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the line buttons on the phone flash red and the phone goes through the factory reset process.
Do not power down the phone until it completes the factory reset process and the main screen appears.
Oct 10, 2014 | Cisco 7942G IP Phone
I cannot register phone in remote location
Duplicate question. See other post for clarification.
Oct 14, 2012 | Cisco 7942G IP Phone
How to upgrade to SIP Firmware on Cisco 7945G
This process should work for you http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Cisco Telephone Power Brick
Sep 08, 2012 | Cisco 7945G IP Phone
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
We are experiencing some NW problems with our Cisco 7940 hardphones. We have several installed and for some time now it seems that these hardphones just lose their default gateway configuration and stop...
I would check the firmware on the phones. Also, check that your switches are properly configured. Duplex settings do matter. If your using cisco switches; do a "show interface" and check for CRC errors etc.
Jun 25, 2010 | Cisco 7940 IP Phone
Blank Screen
I would verify what the firrmware is of the phone. It is possible that the phones need to be upgraded.
Mar 27, 2008 | Avaya 5610 IP Phone
My client has Cisco 7940 IP phones and wants assistance with feature programming
This phone can be access through a menu/ setting buttons.
Useful link on how to navigate through the phone:
http://www.cisco.com/warp/public/779/largeent/avvid/products/7940/7940_topic3.htm
I think the main problem is to determine the intergrated router or Call manager configuration
You can also connect on switch and type:show cpd neighbor This will show the physical port connections
Nov 27, 2007 | Cisco 7940 IP Phone
Computers & Internet Logo
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
