No sound when goin thru hdm1 but sound when going thru scart socket ect 1 on philips tv
bernardlunda
  • 318 Answers
SOURCE: Sound but no picture on either SCART socket inputs
open the tv and check for dry joints on the jacks of AVS, if no dry joint is found
the ariel in put is different from AV inputs
change the AV in IC. AT THE W/SHOP
Posted on Apr 25, 2009
SOURCE: Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Posted on Jun 19, 2009
jamo297
  • 19 Answers
SOURCE: connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Posted on Jul 18, 2009
  • 21 Answers
SOURCE: No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Posted on Sep 14, 2009
falter
  • 245 Answers
SOURCE: 32LG3000 No sound,no DTV
check ur sound volume also if sound is muted this all can be done by ur remote controll
Posted on Nov 20, 2009
Can I hook up a copying device to my LG 26LV2500
Such as a DVD recorder?
Yes, conventionally a recorder takes the feed from aerial or box befiore the TV but recording whatever you're watching can also be done mostly by using one of the Scart sockets usually on the back of a TV usually identified as Scart 1 AV in/out which should be connected to Scart In on a recorder.
If there are digital output sockets - and digital input sockets on a recorder - you'll get higher image and sound quality than you'll get from Scart.
Sep 23, 2011 | LG 26 26LV2500 26 LCD TV
Can I play Nintendo Wii with Philips 14PT1686 Tv?
Hi
Yes you can, you will can use the scart adapter for the audio and video connections ( red, white and yellow) which is supplied with the wii, and connect this into the scart socket of the TV, you will then need to select the scart input of the TV, using the TV remote button EXT or TV/AV (dependent on the model), then set you wii I/R reciever to either top of tv or bottom of tv, dependent on its location and all should be ok.
Regards
TechSupp12
Dec 12, 2010 | Philips 14PT1686 14" TV
I am trying to hook up my vcr and my DVD to the 60pp9202 60 in my DVD is working but my VCR is not. I am getting a black and white picture on one channel and sound on the other.
put the dvd plug scart into the spare scart socket on the vhs player,then u can only use one player at a time,ie if watching dvd put vhs player into standby or vice versa,the other scart socket on the vhs player goes to the tv. when not using either be sure to put both on standby.
Feb 28, 2010 | Philips 60PP9202 60" Rear Projection...
Jun 17, 2009 | Hitachi Televison & Video
Connecting PVR and satellite receiver
make sure you have a connection from one of your scart sockets (assuming you are using scart) on your sat to your pvr and then a connection (scart/hdmi?) to your tv from the pvr.
if you have a second scart or better still hdmi on your sat then plug that into tv
set top box scart output to tv
you do not say which tv model number you have so I dont know what input sockets you have but I will assume a couple of scart inputs and maybe a hdmi in (if hd version of tv) these days that would be considered a minimum amout of inputs so the setup suggestion above should be fine with that
Jul 22, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
