Question about HEWLETT-PACKARD Hewlett Packard Compaq nc4010 PC Notebook
Boot selection failed - HEWLETT-PACKARD Hewlett Packard Compaq nc4010 PC Notebook
  • HEWLETT-PACKARD Master
  • 32,281 Answers
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Posted on Feb 23, 2012
The boot selection failed because a required device is inacessable oxc000000f
Hi
If you can get your hands windows disc, re-install and select repair instead of install, follow the prompts and select boot exe that will replace the missing boot files and should reboot your pc normally.
cheers
Nov 27, 2012 | Compaq Presario 5000 PC Desktop
Why my hp compaq nc6000 laptop failing to boot from cd after selecting multbay
hi ,
go into your cmos or setup for the computer , find boot setup and change it to drive c:\ or hard drive 1 .........good luck Roy
Feb 18, 2012 | HP Compaq nc6000 Notebook
My toshiba will not boot up
Restart laptop, press F8 to enter the Windows Advanced Options Menu. There are many options, try going to the computer via:
1. Last Known Good Configuration (advanced) - enter. If it fails to enter windows, restart - F8 - select
2. Directory Services Restore Mode - enter. If it fails to enter windows, restart - F8 - select
3. Debugging mode - enter.
Dec 04, 2011 | Toshiba Computers & Internet
Stuck on safe mode
Press F8 at boot up and select Normal boot up. Or if that fails to work then select Last Good Boot Up. that will restore the computer to a previous date when it was booting perfectly. That should help you.
Apr 17, 2011 | Dell C521 DimensionTM PC Desktop
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
Computer fails to boot. searching for either hard
These pins are referred to as "jumpers". Each manufacturer can have their own jumper settings. Each device should have letters indicating which pins correspond to master, slave, or cable select. The best method to insure operation is to use the cable select (CS) jumper setting. Using this setting, the hardware will be automatically configured.
Mar 11, 2010 | Compaq Presario 5000 PC Desktop
Error message says PXE-E61:media test failure check cable. PXE-M0F:exiting broad com PXErom. Reboot and select proper boot device or insert boot media in selected boot device and press any key.
PXE errors occur when the system attempts to boot to the network adapter and it fails to find a bootable network connection. In most systems, this is due to the hard drive not being detected in the system. So, reseat the HDD and ensure it is seen in the BIOS. If it is not seen in the bios then it has most likely failed and needs replacement.
Nov 03, 2009 | Computers & Internet
After I select the user to logon it goes to logging off-why?
Try to boot in safe mode first. Im not sure what laptop brand you are using but I want you to boot to safe mode and try it there to login. Now if it fails try to do F8 then select last known good configuration. If this fails do startup repair.
Oct 03, 2009 | Dell Computers & Internet
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Fails to boot
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Apr 16, 2008 | Gateway MT3705 Notebook
HEWLETT-PACKARD Hewlett Packard Compaq nc4010 PC Notebook Logo
62 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
