Question about HP Officejet 4315 All-in-One Printer
Cartridge error, caution this machine could work at any time
I have two refilled cartridges from cartridge world.  a tricolor #22 and  a black #27. I have had no problems with refills in the past.  My printer software and usb port drivers seem up to date.  My printer is hooked to a hub on the base of my monitor which is cinnected to my printer.  Please help me to rid myself of the dreaded CARTRIDGE ERROR!
    Problem Solver:
  • 5 Answers
This does not look like a chip issue (as i can tell from
http://www.inkfilling.com/inkjet-cartridge-hp-22.html )
Every now and then you will need a new cartridge you cannot
refill the same one forever it will go bad, perhaps this is the issue.
Some more info/possibilities at http://www.inktelligent.com/topic_382.html
Posted on Feb 23, 2009
How can i fix this problem
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Apr 24, 2012 | HP Officejet 6310 All-In-One InkJet...
Will 27 black and 28 tri-colour cartridge work on a D1560 hp deskjet
HP 21 black and HP 22 tricolor cartridges are the cartridges compatible with HP DESKJET D1560.HP 27 and 28 won't work with your printer because they won't get recognized by the machine.It will only give you an error message like incompatible cartridges.
Jul 21, 2011 | HP D1560 Deskjet Printer InkJet
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Dec 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
818 cartridge refilling
If you mean the HP DeskJet F380 cartridges (the HP 21 and HP 22 cartridges) you will have unreliable success refilling these cartridges either yourself or online, at Costco, Office Max, and Walgreens. These refillers generally don't have fantastic quality control or knowledge of printer cartridges. I suggest Cartridge World or Office Depot refills. If you mean the HP Photosmart C8180 (the HP 02 cartridges) refilling them is easy but you need to replace the chip on the cartridge for it to work in your printer. As long as a refilled cartridge has a new chip it should work in your machine. Again I recommend Cartridge World or Office Depot refills.
Nov 24, 2009 | HP DeskJet F380 All-In-One Printer
Cartridge error: refer to device documentation to troubleshoot
remove the cartridges and clean the metal contacts with tissue paper and put it back. if the problem continues check the cartridges.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
After refilling i attached the cartridge but not printing printer showing "check cartridge" i have done refilling like this 3 times without any problem but this time i am facing this problem .Kindly...
search for the specific cartridge you have and keywords such as "refill, reset expiration, contacts" for instructions on how to fool the printer into thinking the cartridge isnt expired yet. This works for most HPs:  http://www.refill4.com/refillinstructons/cartridges/hp-56-27-21-57-28-22.htm
Jul 27, 2009 | Office Equipment & Supplies
HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Jun 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
Check print cartridge error
Set the properties to print on HP paper. This usually solves the problems
Mar 09, 2009 | HP DeskJet 3745 Printer
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
