Question about Maytag Appliances Over-the-Range Microwave Oven
Microwave oven sounds like it is still running after the timer/oven goes off.
  • Kermit Feb 23, 2012
    what exactly does it do, does the turn table stop, does the light shut off inside?
How can I get my Kenmore microwave oven to stop timer from running to fast and the clock on microwave is running to fast
Sounds like the microwave thinks it is running at 50Hz. They sense this automatically. most of the time a reboot will fix it. worst case, replace the control board.
Mar 05, 2015 | Kenmore Microwave Ovens
My microwave goes on lights but timer keeps running but no heat
There are three common issues, the magnetron, a cracked high voltage diode, and a short in the high voltage capacitor.
Mar 19, 2012 | Cuisinart CWM-100 Microwave Oven
I cannot stop the DEMO
Demo Mode The Demo Mode is ideal for learning how to use the microwave oven. When set, functions can be entered without actually turning on the magnetron. The microwave oven light will come on, the fan will run, the countdown will run very quickly in the display, and the turntable will rotate. To Turn On/Off: The microwave oven and Timer must be off. Touch and hold TIMER SET/OFF for 5 seconds until 1 tone sounds. Repeat to turn off.
Jan 21, 2012 | Whirlpool Microwave Ovens
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
When I start my microwave, the timer runs but the
Hi,,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Timer runs fast, plus no heat Maytag MMV1153BAW
No... you are not in a microwave induced time warp...
Your microwave oven needs a "reboot". The same thing happened to me.
Unplug your microwave oven, wait about a minute (more or less), plug it back in. Try setting/running your kitchen timer, boil water, etc. Your timer software on the microwave should be reset.
Jun 14, 2009 | Whirlpool MH7135XE Microwave Oven
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
Maytag Appliances Over-the-Range Microwave Oven Logo
156 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
