Question about Sony Handycam CCD-F555 Camcorder
Can't open door - can't eject tape
The camera side door will not open. I have even taken the outer door off to see if there is a level or something. I cannot get the mechanism to move. It is as if it is frozen. There is a tape in there and I can't get it out. What do I do? I need to use this camera to transfer some taped info to a vhs or cd. I need this fast - can you help me with this?
  • 2 more comments
  • asmaida Oct 27, 2008
    I have not tried to forced the door open.
    This is evidentially a mechanical problem. What can I do? I am mechanically adept.
    how do I apply 4.5 volts dc to the loading motor?
  • asmaida Oct 28, 2008
    The tape is the correct size
  • Sony Master
  • 19,396 Answers
I do not think this is any electronic fault.
When old Sony handicam do not open, it is usually because the tape is jammed arounf the tractors inside the camera.
Even if you are mechanically adept, by taking apart the whole camera side panel, unless you have worked on this kind of electronic before, you risk to transform your camera in a bunch of bits and pieces that you cannot assemble back together.
Ensure first tat the camera is powered up, and it is working, eventually connect it to the AC adapter if you are not sure about the battery charge.
Press repeatedly the eject button, and at the same time try helping the door to open, either with your finger or with a plastic lever, do not put too much strenght.
If you can open the door enough to extract the tape, try extracting the tape with long thin plyers, then cut the tape ribbon and remove it from inside the camera.
If that does not work, you need to take apart camcorder side to remove the tape.
If you have to disassemble, better getting the service manual for your product.
I do not have the repair manual for Handycam CCD-F555, but you can buy it here : SONY CCD-F555 Service Manual.
Here you get the manual for a different handycam for free, just to give you an idea on how to use the service manual: SERVICE MANUAL CCD-TR818.
If you need to replace parts after the removal, you also find parts here.
SONY ORIGINAL PARTS
Posted on Oct 28, 2008
  • 4,234 Answers
I'm sorry about the discourse you have witnessed here. Lets get to the problem at hand.
First, these are not the easiest units to open up without damage to internal cables. That being said, perhaps a little more info would be helpful in tracking down the problem. When you attempt to eject the tape, do you hear any motor attempt to run? We need to determine whether or not the unit even realizes that you wish to eject the tape. Does the unit turn on at all? Any indication of activity in the viewfinder?
With the cover removed, can you see the tape? Is it wrapped around the heads still or is it inside the cassette?
Please update this and we'll move on to the next step based upon your responses.
Thanks,
Dan
    Genius:
  • 1,847 Answers
The tape can be manually ejected by using the VTR menu.
  1. On the VTR control panel, press MENU + LEFT ARROW simultaneously.
  2. Press the UP ARROW or DOWN ARROW button until SUPPORT SERVICE is selected.
  3. Press the RIGHT ARROW button.
  4. Select the MANUAL EJECT option, then press the RIGHT ARROW button.
  5. Follow the on VTR display instructions to manually eject the tape.
  6. NOTES:
    • If the problem persists remove the VTR cover and locate the S201 switch on the SS card and set switches ONE and FOUR of the S201 to the on position so the VTR is set to service mode.
    • The switch is sometimes tricky to locate, because it looks like a dual in line IC at first glance however, it is a set of eight switches.
    • The switch is in plain view on the top left of the card when viewing from the front of the VTR.
  7. Press the EJECT button from the control panel.
  8. NOTE: If the tape will not eject after several attempts contact the nearest Service Center for assistance.
    Hope this will help
    Thanks
    Kevin
  • 320 Answers
Do NOT apply voltage to the loading motor. This is a BAD IDEA as you will likely fry the drive circuitry for the loading motor and compound the problems you already have. You best solution is to take the camcorder to an authorized service center to have it checked.
Posted on Oct 27, 2008
  • Any Guy
    Any Guy Oct 27, 2008
    Good idea welcomejee, recommending he disconnect the motor before applying the voltage. Wonder where you could have got that from? Might have helped to consider that BEFORE you suggested he apply voltage to the motor.
  • 728 Answers
Was the tape you put in the right size and model? If not, that could be the reason the door jammed. It could have got caught up on the tape. Check the tape case to make sure it is the right size. If it is not, you might need to get a screw driver and unscrew the whole thing manually and see if you can eject it manually that way. Then check to make sure the motor has not burnt out. You might need it replaced.
    Genius:
  • 1,550 Answers
There is some mechanical problem in your camera .
You gently tap on the sides of camera and try to open the tape .
    Scholar:
  • 155 Answers
Do not force it to open.as it should normally open please check if something is blocking the side door to open..
do it gently.
reply
  • 10,594 Answers
How old is your camera?
Seems it has weak capacitors in circuit.
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Oct 27, 2008
    Your camera CCD-F555 is 1991 model ( 17 years old ) and definitely has many weak capacitors on circuit boards.
    In my opinion, it can not be repaired. If you want to take out cassette, you need to open camera and apply 4.5 volts dc to loading motor, so mechanism will move to unloading status and cassette can be ejected in that way.
    Good luck.
    You need to open side cover of camera and there you will see cassette mechanism, there is loading motor at left corner of mechanism near video head (drum assembly), apply 4.5 volts by using external power supply, if you have.
    above 4.5 volts application solution is just to take out cassette only.
    let me know is this camera 1991 model or not?
    One thing important...
    disconnect loading motor 2 wire connector from circuit board before applying 4.5 volts to eject cassette.
    Shahid Electronics Oct 28, 2008
    @mistersony,
    CCD-F555 is already fried item as its 1991 model.
    I forgot to mention unplug motor connector in 2nd comments and later I realized it.
    Thanks for your concern.
Tape Eject Mechanism
How much did you pay for the Camera? Want to send it to a Repair shop, or try to fix it yourself? I have links to repair manuals and one to a repair shop in Florida. Post a reply if you want those links.
Feb 10, 2014 | RCA Video Cameras
Eject mechanism issue.
The estimate depends on the extent of the damage... if it is just a matter of reallignment I would estimate $50-100 at most shops. But based on your description, it sounds more likely that parts of the transport are irrepairably bent or broken and will need replacing, which would put the estimate around $200-350.
Oct 04, 2007 | Sony Handycam DCR-PC5 Mini DV Digital...
Sony mhc-2600 tape stuck
The tape has spewed out in the mechanical section preventing the door from opening, some outer doors can be removed by too thumb screws sliding up and out, others are held in by plastic clips, the door may have to be pried open to get the outer door off to remove the tape.
Jul 27, 2012 | Sony Audio Players & Recorders
Panasonic m7 vhs video camera while in play mode camera stopped and made whiring noise then shuts right down will not eject how do you get tape door open manually
Hi, open eject door,try to see very small lever at the left side cassette at lower end and try to pull it at your side with very thin and at least 4 inch long screw driver.Cassette compartment will open. But its not so easy to find.It need patience.
Aug 10, 2010 | Video Cameras
Sony PC-105 - camera won't charge, hence tape will not eject. Is
I just had the same issue except I left my camera out in the rain. My camera is a DCRF-HC32 Sony Handicam. There is a reset button on the side of the camera where the eject door is. Take a paper clip and hold the reset button in for 5-10 secs. The camera will beep, power on, open the door and it ejected.
Jan 21, 2010 | Sony Handycam DCR-PC105 Mini DV Digital...
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Won't Eject Tape
same problem, after you hit eject is pops out and never opens up, to the right of the "push" button is an arm with a spring, pushing it back will open that side, on the left side is a pin with an arm you can move the arm back the pin moves and the other side will open as well, wont fix the problem but will get you your tape back.  I have a very upset wife, we had a jvc mini DV went out one winter change in temp killed it instantly, now our canon has sat a few years and wont work either,  we bought a flip video, it works.
Oct 06, 2008 | Canon ZR60 Mini DV Digital Camcorder
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Tape door will not open
the tape eject door will not open there is currently a tape in the camcorder (panasonic pv-l559)
Jan 09, 2007 | Panasonic PV-L559 Camcorder
Sony Handycam CCD-F555 Camcorder Logo
521 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
