Question about HP (344872-001) Laptop Cooler, Cooling Fan
Cooling fan 902 error - HP (344872-001) Laptop Cooler, Cooling Fan
3 Suggested Answers
SOURCE: system bios says the is a 902 cooling fan error
Replace the cooling fan. It is going bad and will cause the laptop to overheat.
Posted on May 25, 2012
Geekman
  • 32281 Answers
SOURCE: cooling fan 902
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Oct 29, 2012
Hp envy 15 fan error
Hi
here is the link to dissasemble the unit
http://www.insidemylaptop.com/disassemble-hp-envy-15-notebook-replacing-keyboard/
please put all crews back in the right place and wear esd wrist strap.
take the radiators off use tim thermal compound cleaner then dissasemble the fan and take out the dast particals.then blow the radiator out with electric solvent cleaner so nothing gonna remain between the plates.then assemble the fan back and apply new thermal compound just on those parts where was.leave the silicon pads.if they are broken or old you have to replace them.
usually the latest hp laptops having problem with bearing they just dry out i use wd40.you need just one drop in the right place.
Mar 21, 2013 | HEWLETT-PACKARD HP ENVY 15 Series Notebook...
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
915 service motor error
The error means that the printer is detecting that there is Fuser cooling fan failure. Check if the fuser cooling fan is installed properly. If it is, check the fuser cooling fan for operation. Follow the steps below:
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Fuser cooling fan.
Does the fuser cooling fan RPM increase? If yes, perform a print test, and if the error continue, replace the printer engine card assembly. If no, check the fuser cooling fan for proper connection.
Nov 30, 2012 | Lexmark W840 Printer
Cooling fan 902
Oct 28, 2012 | HP Computers & Internet
System bios says the is a 902 cooling fan error
Mar 04, 2012 | HP Mini 110-1037NR Netbook
Fix HP lapton error 902 cooling fan
the laptop was fixed by blowing into it
do it very care fully.
Feb 04, 2012 | Computers & Internet
Error 902 kyocera 1500 and also give to me error list.
Please check again 902 does not show it must be A**** or C****
Oct 30, 2011 | Kyocera KM-1505 Copier
This morning when I tried to start my laptop ( HP Pavillion entertainment PC) I got a flash window that due to the cooling fan 902 issues the start up could not happe and I have been advised to contact...
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 04, 2011 | HP (219462-001) Cooling Fan
I purchased a compaq CQ62 112TU laptop with a 32 bit windows 7 operating system 5 months ago.today it showed me a cooling fan error..error (902).nd windows is not starting.please help mee....:(
if its only 5 months old you should still have warranty on it you should contact the place of purchase before doing anything
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
try blowing the dust from the fan and your laptop computer computer dust will cause static which can cause a computer to overheat and many unforseen problems also
you could get a usb laptop cooling pad they are very cheap and your laptop will love you for it
hope this helps
Mar 18, 2011 | Compaq Presario Fan
Cooling fan (902)
in monitor display " Cooling fan (902), problem on the fan, it could be the motherboard detects the fan is not spinning, it could be the fan spins slowly, opening her fan motherboar and check if it needs to change, then the problem is solved
Jun 02, 2010 | HP (219462-001) Cooling Fan
Computers & Internet Logo
310 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
