Question about Clarion NX501 Car Video Player
Clarion NX501 US version in Europe
I bought a Clarion NX501 from the US not thinking it'd cause me too many problems to use here in Ireland. Little did I know. I've overcome most of them ISO wiring harness adapter, european maps etc. I am however stuck with the radio that doesn't pick up most of the local stations due to different frequencies. I've seen on Clarion's support portal the following: "Q4. How do I change the tuner frequency spacing for use outside the U.S.? A4. With our C-Bus units, press and hold the BAND button, and move the Alpha Touch left or right. With our CeNet units, press and hold the RANDOM button, and PRESET #1 to change from U.S. to European frequencies. Each press of the PRESET #1 button will cycle the tuner frequencies." I can't see this applies to the Clarion NX501. Does anyone have a suggestion for me? I've toyed with the idea of buying the Clarion THD400 HD radio tuner and go HD radio instead of analog but not sure if that will work here in Ireland because the radio tuner is again US rather than European version. Thanks in advance for any help
5 Suggested Answers
SOURCE: preset radio
The best way to do this is to be very patient. find the station you want to preset and simply touch and hold the number you want to save it at on the touch screen. the station will pause for a split second and then you will see it on the display of the presets
Posted on Feb 06, 2009
604Autosound
  • 162 Answers
SOURCE: i have a clarion navigation package NZ500 and it
I would recommend returning to the dealer you purchased from and having it sent in for warranty repair.
Posted on Feb 04, 2011
SOURCE: clarion cz309 radio frequency step
I got a clarion CZ309 and I can't get it out of amp_gnd mode how do I change it
Posted on Apr 25, 2011
  • 26 Answers
SOURCE: I have an error message coming up on my Clarion
take the navi card out and stick it in your computer then partition it then update it online with new navi software reinstall the card this should fix your problem
Posted on Sep 21, 2011
Clarion radio nx501 audio 2 screen goes blank No noise level bars.
I recommend you contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Jul 10, 2017 | Clarion Car Audio & Video
My screen on my clarion nx501 has lines down on it
I would recommend using electronics cleaner (or a q-tip with a little alcohol on it) on the contact points of the card. Dirty contacts will cause this issue.
Dec 29, 2016 | Clarion Cell Phones
I have the manual for the Clarion NX501, but it does not tell HOW to set clock.
Page 51 of the manual, under General Setup Menu, is Clock.
Here is where you set time, AM/PM, or 12/24 hour clock,
Nov 02, 2015 | Clarion Car Audio & Video
I have a Clarion 501NX. The Navigation will not work. Was a micro chip supposed to come with it. I looked in the door and no chip was inserted in it. The unit came with a motorhome that I just bought
The small slot is for a MicroSD (storage) card which is not required to be used for operation. I have no experience with this model but here is the link to the 160-page manual which you likely don't have. This may provide enough detail to resolve your problem.
Download manual
Nov 17, 2014 | Clarion NX501 6.2 SINGLE-DIN NAV...
Clarion nx501 with hino and password
i hAVE the same exact issue and the 4 digit password to unlock it is the last 4 numbers the HINO trucks V.I.N... they say u only get 3 tries and it locks it and the only way to unlock it is to contact clarion... lick my balls clarion the default password is 0000 and u get 3 tries but just disconnect the power and reconnect the power and BAM... you will be asked to enter a security code all over again...0000 that is your unlock code.
as for the start- up HINO screen... good luck. its called a splash screen and you would have to hack clarions firmware in order to do so and i suppose if you were able to locate the internal hard drive but even then. clarion invested billions to protect their operation systems in their devices. i think the image is burned into the chip where the head unit was sent from a hino dealer brand new in a box directly to clarion's I.T. to have changed cause it comes factory as a clarion boot screen.
you will also notice that the hint clarion nx501 wiring harness is altered so to make work in that truck that only comes with two front speakers.... the rear speaker leads are nowhere to be found; GONE like a new brides panties!.. you also won't have any rya leads ect.. gay gay situation and if u figure out the splash screen change let me know.
peace.
S.D
Jan 16, 2013 | Clarion NX501
My remote doesn't work on the new clarion nx 501 either. The shop that installed it gave me a new one but that doesn't work either? The battery has power but the remote does nothing. Any...
the unit may be faulty from the factory most shops will try every thing other than swapping out the unit because that cost them time and money unless it is a bluetooth remote then the radio will need to be programmed to except the signal the remote is putting out hope this helps if not let me know and i will do more research on that unit good luck
Oct 10, 2011 | Clarion NX501 Car Video Player
I have an error message coming up on my Clarion NX501 in dash navigation system "Out of Memery" "Requested: 2416555267" "Cache : 0" Navigation will not come up at all....
Sep 21, 2011 | Clarion NX501 Car Video Player
I have a clarion nx501. The micro sd card that has the navigation on it is corrupted. the guys at clarion said that they can't cover this under warranty. please tell me what my options are. i heard...
Please read my post here: http://community.crutchfield.com/forums/p/22187/251957.aspx (pasted below).
I hope you bought your unit at a Clarion dealer....
Hi, (Team Crutchfield - please add this to your knowledg-base.)
I'm on my third NX501 (could have been the fourth if not for working directly with Clarion).
The SD Card corruption causes both loss of Navigation and intermittent Sirius start up (it'll never acquire signal).
Your unit needs to use the exact micro sd card it came with forever (it has a permanent serial number).
You have two choices:
1. Get Crutchfield to replace the unit
2. Call Clarion (I suggest this rather than ripping your dash apart over and over).
Here's what to do. Contact:
Ben Kwan
Customer Service Technical Representative
Clarion Corporation of America
800-347-8667 ext 4342
Direct Line: 310-217-4342
Fax: 310-217-4243
Ben will have you send your microsd and rebuild it for you and return it (likely with the firmware upgrade that addresses this issues on another microsd that can also be found here: http://clarion.com/ca/en/support/navigation_updates/NX501Fupdate/index.html).
While you're at it, update the Bluetooth firmware too: http://www.clarion.com/us/en/support/software/NX501/index.html
Once you get the card returned (THIS IS HUGELY IMPORTANT - EVERYONE WITH A Clarion NX501 SHOULD DO THIS!!!), back it up using Naviextras toolbox (the program clarion uses for map updates). You can get it here: https://clarion.naviextras.com/shop/portal/downloads
Once you follow these steps, barring your micosd physically or logically self destructing, you'll have an NX501 that's nearly problem free and backed up just in case that unfortunate corruption reoccurs.
Of Note: Ensure you insert the microsd card with the contacts facing up and do not force anything.
I'm extremely confident this will make a world of difference for you (and anyone suffering the microsd corruption of the Clarion NX501).
Regards,
Marc (mshmovie)
Sep 01, 2011 | Clarion Car Audio & Video
Clarion NX501 Car Video Player Logo
144 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
