Question about Intel D915GAV Motherboard
My pc mobo is intel 915gav. processor is P4 pinless running with 1 gb 400 bus ram..after a new installation of win xp i worked hours continously..but in in next morning when i turn on pc after running
Port like mouse keyboard ...no thermal paste beteen cpu and mobo but no overclocking...idle temperatue was 47c..i do simple work like typing and listening songs and music videos....no gpu on board ..no physical damage error messege
    Top Expert:
  • Intel Master
  • 74,459 Answers
Hello
There will be a thermally conductive paste [Heat sink compount], a white tooth paste like substance, must be applied between the heatsink and the CPU. It is a must. If you have replaced, or unlocked the heat sink metal, and haven't applied this thermally conductive paste, proper heat transfer from CPU and the metal heatsink will take place, and the CPU will overheat, and finally go out.
Music videos are large files, which apply a great load to CPU, as processing video is a great task for CPU. Temperature must be below 40 degree centegreade, at any instant.
Just unlock the heatsink lock, take out the CPU heat sink out, and apply some heatsink compound [silicon grease] and retry. If you hear a beep sound after 3 seconds or so, after swithch ON the system, you have won. OK.
http://www.dataentryjobs.us/67948.html
Posted on Feb 22, 2012
Win xp runs slow
You can speed up your Windows XP PC by following steps:
1. Delete unwanted files and programs in your PC
2. Install Antivirus (AVG free version) and update and scan
3. Install super anti spyware app (Super antispyware free version) update it and make quick scan.
4. Make hard disk defragment.
5. First of all system requirements for windows xp (CPU: Intel P4, RAM DDR2:1GB, HDD: 80 GB)
Jan 02, 2014 | Microsoft Windows XP Professional
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I have an HP Pavilion a335w computer. It's running a P4 2.5GHz processor (Northwood A80532) 512 L2 with a 100MHz FSB. It has a TriGem Glendale motherboard, PGA478 socket, and it's maxed at 1MB RAM. How...
I have a Compaq that came with this board and a celeron 1.8 or 2.0 I believe. The fastest P4 that will run is a Intel Northwood 2.8 Ghtz 400 FSB nothing ELSE! Northwood 2.8 is the fastest 400 FSB, the boards chipset won't run anything faster than 400 FSB. Mine is running, Win 7 the Northwood P4 2.8 with 2 gigs ram, 160 gig HD and a 256 video card for over 5 years (minus win 7, had XP before with no issues. Good for light gaming, web surfing and MS office! Add a Zotac 512 MB PCI or Sparkle Video card and you can handle most more medium gaiming out today!
Dec 18, 2010 | HP Pavilion a335w (Refurbished...
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Jan 28, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Mercury motherboard PVM7Pro V:1.0
j'ai besoin des drivers audio de la carte mère MERCURY PVM7 V: 1.0
Apr 03, 2008 | Intel Motherboard
Poor game perfomance
What resolution are you playing at? Did you unistall the old card properly first and use drivercleaner pro to remove all traces of the old drivers?
What card did you upgrade from?
Also what version of the card drivers are you using?
Dec 13, 2007 | Computers & Internet
Game poor perfomance
dl latest driver least get 500 watts dual rail power in it to suppert that hungry beast and need alot fans many as u can install in case drivers ther working on dl latest one ever 2 weeks fixxes for it get big power tho set the settings nvidia to top perfenece not quilty to by pass certain things run game sin 1024x768 run cc cleaner also make sure comp clean from junk
Intel D915GAV Motherboard Logo
89 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
