Question about Asrock 775i65G Motherboard
Time is not updateing
I am changed so many cmos battery but time is not updating. what to do
  • Asrock Master
  • 27,725 Answers
if you are talking about the time on your computer
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time internet time tab hope this helps you
Posted on Feb 23, 2012
My Gateway laptop won't boot up it keeps saying "failure configuring Windows updates reverting changes" Do not turn off your computer
Make sure the Date & Time are set correctly on your machine. That can interfere with Windows Update. If your computer has the wrong date/time, you need a new cmos battery (available anywhere). Then, If you are running Windows 7, try the "Windows Update - Reset" options here... http://www.sevenforums.com/tutorials/91738-windows-update-reset.html?filter
Jul 16, 2014 | Computers & Internet
I have recently updated the system bios it's successfully upgraded but the problem is its giving CMOS Checksum bad error please I yesterday buy the system
Hi.
Exist some problems that can cause that:
1- The CMOS battery. Solution: Change it for a new one.
2- Some problem with the time specifications in the BIOS.
3- Some drive that isn't connected properly.
Mar 01, 2013 | Radio Communications
Foxconn n1996 chip needs replacing as had power cut as updating bios
Reboot the computer.
If error still occurs after rebooting the computer enter CMOS setup and check all values, this includes verifying the time and date are correct.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Once everything has been verified and changed make sure you save and exit CMOS setup.
If everything appears to be correct and the issue persists try resetting the CMOS values to the defaults or Reset Configuration Data.
If this issue continues to occur after you turn off your computer off it is possible that the CMOS battery may be failing or already bad. Before considering replacing the CMOS battery try leaving your computer on for several days.
If a BIOS update has been run on the computer the values stored in CMOS may have been reset. Enter CMOS setup re-enter all values and then save and exit CMOS setup.
If you're unable to enter the CMOS setup or after running a BIOS update your computer no longer keeps its values the incorrect BIOS update may have been installed for your computer or the version downloaded may be corrupt. We suggest trying to update the BIOS again or reverting back to an earlier version.
Hope it helps
Nov 09, 2011 | Dell Studio Xps 9100 Desktop Computer
Bios settings changed automatically
Have you tried to update the bios? One of the latest versions BIOS Update [DPP3510J.86A] 07/15/09. But verify to ensure that you download the correct bios for your board. There are a few options available. Also check the jumper pins for the bios on the motherboard normal or (default) setting is pins 1-2 jumped.
Nov 10, 2009 | Computers & Internet
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
Hi there.
Basically you first bios update was bad, if you can get into the operating system re-flash the bios again, that will sort it out.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Windows XP Professional Upgrade...
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
HP ZE5185 Clock Problem
they are all rechargable you need to keep sufficient charge in battery.imagine if you didnt charge your mobile phone for 6mth.
Apr 09, 2008 | HP Pavilion ze5185 Notebook
Thinkpad 380ed
1) This is a typical problem when the CMOS battery is very weak or dead, it will continually display the date and time and reboot with the same errors until you change the CMOS battery. On this model it is behind the door that houses the memory chip, above the battery, if you have the laptop turned over and battery closest to you. <--best bet, its a dead CMOS battery.
2) You can get to the BIOS to run tests, one of 2 ways, either hit the ESC key and other keys to get a 301 error or hold the F1 key and boot, you should get into BIOS. (You probably won't be able to do this until you replace the CMOS battery.) From there you can run diagnostic tests on various components.
3) Lastly, you can update the BIOS. From inside the EASY-SETUP bios you should be able to copy the BIOS part number, date, etc. Look for the BIOS update based upon model # either thru a search on the web or directly on the IBM website (a search on google of "bios update thinkpad 380ed" will bring up a link for the IBM page.) If you choose to do a BIOS update, read the directions carefully and remember not to power off the machine while the update is happening. If you've never updated a BIOS before, get someone who has to walk you thru it before attempting it by yourself.
GOOD LUCK :)
Sep 19, 2007 | IBM ThinkPad 380ED
Asrock 775i65G Motherboard Logo
27 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
