Question about Canon PIXMA MP495 InkJet Printer
Print envelope on an Canon MP495
Can't figure out how to get the printer dialog to understand I am SETTING it to envelope AND #10 envelope and every other combination thereof.
  • 3 Answers
SOURCE: Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Posted on Jan 09, 2008
  • 79 Answers
SOURCE: Envelope prints the wrong way
This may be a very inconvenient solution but if your desperate then try it. The label you are trying to print : Take a snapshot of it using the print screen button on your keyboard and then paste it into paint. Cut out everything except the label then use the page setup feature in paint to make sure its in the right spot. Dont forget to choose envelope in the page setup and in the printer settings.
Posted on May 02, 2008
rhoncruz
  • 134 Answers
SOURCE: How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Posted on Dec 01, 2008
Amidamaru001
  • 78 Answers
SOURCE: Not printing envelopes and printer locks up
Use a small flash light and check for any debris blocking the roller from the tray...
Posted on Sep 24, 2009
SOURCE: Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
Posted on Dec 11, 2011
Nov 22, 2011 | Canon PIXMA MP495 InkJet Printer
How do I print an envelope?
Put the envelope into the fold-down tray narrow end first with the side you want to print on facing up. After you click print in the application click on the 'options' button in the print dialog box and select the envelope size, check the media types to see if envelopes is listed, pick the most appropriate setting.
Aug 21, 2011 | Brother HL-5240 Laser Printer
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I have a Canon MP460 & cannot print DL envelopes from a .pdf as there is a grey band showing in preview:composite. Nothing prints in this band. How do I remove it?
This appears to be a bug with the Canon software. It is not using the correct dimensions for a DL envelope.
The solution is to use a Custom Paper Size. Make it 110mm wide and 220mm high (which are the correct dimensions for a DL envelope).
To make it easy to select this size in the future, set the Custom Paper Size (plus any other options you want) and then click on the Save button. When the save dialog appears, click on Options and make sure that "Save the paper size setting" is checked. Then enter a suitable name (e.g., "Envelope DL Custom") and click OK.
Nov 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot print envelope on MX310
Note:
    Note:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Print 6 3/4'' envelopes on a Canon d320
Press additional functions button, then use the + button to go to paper setting and use the + button to get to paper size, then using the + or - button to get to envelope and then if you push the + or - button you will get different sizes i suppose they are, but not sure what exactly they mean. I don't have any small envelopes to test it with your specific size, but finally just realized on to print #10 envelopes on it.
Feb 20, 2009 | Canon imageCLASS D320 Digital Copier
Xerox Doc 12
should be ok if you use the bypass
Jul 31, 2008 | Xerox DocuColor 12 Color Copier
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP495 InkJet Printer Logo
1,124 people viewed this question
old marine
old marine
