Question about Whirlpool Washing Machines
Whirlpool washer Model LA5300XS water leak
This oldy but goody has just started to leak water. I looked under the washer and there are no leaks by water supply or hoses. The water seems to be dripping above the motor. Do you think it is repairable or should we call it quits?
5 Suggested Answers
SOURCE: Whirlpool Cabrio Leaks Water
you probably got coins or junk in the water pump on the bottom back of washer and it poked a hole in the housing. Thats what happened to me
Posted on Sep 16, 2008
  • 239 Answers
SOURCE: WHY is water leaking under the unit. It's not the supply hoses.
pump seals are bad
Posted on Jan 17, 2009
  • 98 Answers
SOURCE: Amana washer model LW6501W2 leaks in front during fill up
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Apr 01, 2009
SOURCE: washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge washers are horrible
Posted on Feb 07, 2012
Hi i have a mitsubishi verada 1998 it wont idle down can anyone suggest wat it might be
wow an oldie but a goodie !!! 1998 !!! first id look to make sure the throttle isn't stuck , old aluminum gets corroded and likes to stick a bit then id look 4 any cracked and broken hoses on the manifold , if any of these leak air it will high idle
Aug 03, 2016 | Mitsubishi Cars & Trucks
Whirlpool wtw7300xw2 washer leaking from bottom
check for cracked pump hose/ loose hose, leaking pump, small tube up to water level control
if the water is grey or whitish then it could have water in the gear box from a failed shaft seal
Apr 03, 2016 | Whirlpool Washing Machines
I have a Whirlpool washer that's leaking water onto the floor. Jason Harris told me to look under the heater i don't know where the heater is.
There is no heater on that machine.
Does the water leak as soon as you start the fill cycle or does it start to leak when the water level gets up to the agitator?
Oct 20, 2012 | Washing Machines
Water was seeping thru the front opening while weasher was not in use. not an external leak. turned off both water suppiles and the water leak stopped. siounds to me like an internal valve leak
you need to change out the water valve on the the door and look for the model your parts store and give them the full model number off of the washer,look around the opening on the frame where the door closes into and they will sell you the correct part
Feb 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
There is water leaking out of the bottom of the washing machine
I would check to see if the pump is leaking. Tilt the washer up and put on two peices of 2x4. Shine a trouble lite under washer and take a mirror to look under the washer. Fill 1/2 full of water and advance timer to the spin cycle. Observe to see where the water is comming from. The pump is located at the front of the washer.
If water is leaking from the pump. Replace pump.
Dec 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaking into tub
This sounds like a bad water valve. Replace the water valve and it should stop the water leak.
Jan 20, 2009 | Whirlpool LSR7333 Top Load Washer
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fron load Duet washer leaks
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
