Question about Sharp LC60E88UN 60 in. LCD TV
Picture keeps coming in and going out
Not sure which model if a problem i can find but have pic for about 2 sec then no pic bout 10 sec repeately
Picture and sound come and go on antenna or dvd
Try another lamp. Error 5 is Lamp power supply, but its usually always the lamp bad.
Mar 27, 2014 | Sony Grand WEGA KF60WE610 60" Rear...
Tip
Gm cars and trucks with security light on, veihcle will not start,stall after a...
a relearn of the key may help and is done with the ebrake up to keep the day time running lights off . put key in the ignition and turn it to the on position right before crank for 10sec. turn it off for 10 sec. then turn it back on for 10 mins. repeat two more times back off for 10 sec.and then back on for 10 mins. it iscruishle you try to keep with in the times or very close. 10 seconds and 10 minutes three times and that will relearn the key.
this will work for passlock 2 systems and newer.
on Jan 04, 2010 | Chevrolet Corvette Cars & Trucks
Tip
How to preform a key relearn for gm cars and trucks
a relearn of the key is done with the ebrake up to keep the day time running lights off ( not an issue for you) but do it anyway. put key in the ignition and turn it to the on position right before crank for 10 sec. turn it off for 10 sec. then turn it back on for 10 mins. repeat two more times back off for 10 sec.and then back on for 10 mins. it is cruishle you try to keep with in the times or very close. 10 seconds and 10 minutes three times and that will relearn the key.
on Jan 04, 2010 | Pontiac Grand Am Cars & Trucks
Nikon l810 doesnt switch on, green light comes on then goes off
you may need to set the timer longr to take the picture also be sure to open the lenses or remove the batttery yt reset be sure to used right can of batterys
Aug 27, 2012 | Nikon COOLPIX L810
Blue on the screen of the tv
Try to initialize it!
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight "MEMORY INTI", arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Jun 23, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
My camera stops when I try to take foto. What I need to do?
the focus is probley not focused and the camera has a program to prevent u taking pics when its not focused or is focusing at the time u press the button.
( and its a stupid concept) or if u been taking many pics within a short time like a pic every 2 secs ur memory card speed may not be able to keep up with the pics being downloaded to it. temporaily making it so the camera will not take pics untill the others are on the card.
make sure u partaly press down the picture button so the camera will go into auto focus mode. when it beeps ( most cameras beep) u can take the shot.
Oct 25, 2010 | Samsung S1050 Digital Camera
Tv discoloration
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
Aug 29, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
Sharp LC60E88UN 60 in. LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
