Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Macbook MB403LL/A turns off when tilted - Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
  • Apple Master
  • 739 Answers
Hi Bernie
Apple store job I'm afraid.
You have either a loose battery connection (which is not likely), or you had a broken wire in the hinge that takes the signals to the screen That is more likely. Either way is a job for the workshop.
Posted on Feb 23, 2012
15' macboo pro 2008 15' screen problem. Colors turn negatitive when screen is tilted a certain way.
sounds like the video cable is pinched in the hinges. This was really common with first generation macbook air. iFixit.com has guides for disassembling, but you'll quite likely need a new video cable.
Apr 18, 2014 | Apple Customized 15" MacBook Pro Laptop...
Reset macbook pmu
An Intel-based MacBook uses an SMC rather than a PMU. If you need to reset the SMC, follow these instructions. Intel based Macs Resetting the System Management Controller SMC
Dec 21, 2013 | Apple MacBook MB403LL/A White - 2.4GHz...
How can I eject a mini DVD?
What you could try is tilt your macbook so that the disk drive is pointing to the ground shake the macbook lightly and hopefully gravity will allow the dvd to drop out. Failing that if it is still under warranty take it to the genius bar at your local apple store and they should be able to get it out. Hope this helps.
May 22, 2013 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
How to eject a cd
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility which is located in applications and then in the utilities folder and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVDicon1.png drives in all macs are a bit suspect and if your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge. Hope this helps.
Apr 30, 2013 | Apple MacBook Pro Laptop Computer with...
How to eject a disc from an apple iMac
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
Finally what to do is try pick up your macbook tilt the macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
Hope this helps.
Jan 09, 2012 | Apple Computers & Internet
I have put a mini Cd into my Mac book and the computer hasnt recognised it and I dont know how to eject it? Kay
What to do is to pick up your macbook and tilt the macbook to the one side, press the eject key and the effect of gravity will allow the DVD to fall out. The MacBook DVD drive is not designed to take mini CDs. Hope this helps.
Sep 28, 2010 | Apple MacBook Mac Notebook
How can i remove the dvd from my mac, it is stuck. macbook pro 17 inch
Finally what to do is try pick up your macbook tilt the macbook to the one side and ise the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
Sep 27, 2010 | Apple MacBook Pro 17-inch 2.4GHz Notebook
MacBook Sound Driver Issues
Sounds like the cutout switch in the output jack is stuck open, it is a techy fix sorry (at least it is not a board failure)
Jun 02, 2009 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
MacBook Screen Problem
Hi there
If I understand you correctly from start up the screen is dim but does brighten up after time? But now after start up you are getting a flicker how ever a restart solves this.
On the dimming issue. Check your energy saving settings and brightness key is working OK.
The flickering is a bit of a concern.
Just a couple of questions.
Are there any dead spots on the screen? Areas where there are no pixels.
When you tilt the screen forward and backward, does this effect the brightness or flickering?
Paul
Sep 03, 2008 | Apple MacBook Mac Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
130 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
