Question about Avision AV 121
AV 121 COUNTER RESET - Avision AV 121
How do I check the number of copies the photocopying machine has made (Sharp 5620). Thanks
Download User manual, page 121, CHECKING THE TOTAL OUTPUT COUNT AND TONER LEVEL.
Hold down zero Key and display will tell you 3 + 3 numbers of counter. (audit mode is off)
Sep 03, 2016 | Sharp Office Equipment & Supplies
Reset
what?
Jun 10, 2013 | Avision AV 121
Error code (E8)
Error E08 In Avision AV 121, what's wrong with that?
Aug 11, 2011 | Avision AV220 Pass-Through Scanner
Avision AV121. Won't feed paper.
my scanner AV121 hanged while scanning documents, first from the software then hanged in feeder and wont scan any more?
Jul 31, 2011 | Avision AV 121
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
I have accidentally blocked my Aircel no. 8575163316.. Can't u please giv me the PUK code no. ??
Contact Aircel customer care and ask for the PUK code, they will supply you with the needful after verifying you identity.
Aircel customer care:
S.No. Circle From Any Number From Aircel Number Only 1 J & K 9858012345 121 2 Chennai 9841012345 121 3 Rotn 9842012345 121 4 Kolkata 9804012345 121 5 WB 9851012345 121 6 Orissa 9853012345 121 7 NE 9856012345 121 8 Assam 9854012345 121 9 HP 9857012345 121 10 Bihar 9852012345 121 11 Delhi 9716012345 121 12 AP 9700012345 121 13 Kerala 9809012345 121 14 Karnataka 9738012345 121 15 Mumbai 9768012345 121 16 UP(E) 9807012345 121 17 UP(W) 9808012345 121 18 ROM 976212345 121 19 Gujarat 9722012345 121 20 Haryana 9802012345 121 21 MadhyaPradesh 9806012345 121 22 Punjab 9803012345 121 23 Rajasthan 9782012345 121
Apr 11, 2011 | Nokia Cell Phones
Install in my computer and no work correct and not saw in taskbar .
go to msconfig then set all the settings to default
Oct 25, 2010 | Avision AV 121
I replaced my Pojection lamp and it says to reset timer. I click menu and i get down to where it says timer and it wont let me press okay to reset it!
OK SO ITS NOT LETTING USE THAT OPTION ON THE MENU,HERE IS A LINK THAT WILL SHOW YOU HOW TO RESET IT IF YOU HAVE THE REMOTE HOPE THIS HELPS
http://www.fixyourdlp.com/2007/04/06/how-do-i-reset-my-lamp-timer-counter-after-replacing-my-lamp/?click=48428
Nov 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Avision AV 121 Logo
170 people viewed this question
Top Avision Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Avision Office Equipment and Supply Expert? Answer questions, earn points and help others
