Question about Philips Magnavox 9P6034C 60" Rear Projection Television
How do i get a copy of the owners manual iam having trouble with the tv blocking the channels i cannot remember the access code or dont even remember having one
TVtechmaniac
  • 140 Answers
SOURCE: smartlock code
1.Press MENU to show the on-screen menu. 2. Press VOL+ or VOL- to highlight SET. 3. Press CH+ or CH- to highlight PARENTAL CONTROL. 4. Press VOL+ or VOL- to display the SECRET CODE screen. 5. Press VOL+ (on the remote) and the CH+ button on the front of the TV at the same time. 6. Press the Number buttons to enter a four-digit code. The code will appear on the screen as you enter it. The code "0000" is the default of the TV. If you have not set up a code previously,then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000"). 7. Press MENU to save the code.
Posted on Oct 10, 2007
  • 60 Answers
SOURCE: reset code for channel access
What's the model on the TV? Can try to look for the manual online. Might be worth a shot to try a capacitive discharge (unplug power, try to turn tv on a couple of times while power is unplugged, plug back in and try again). That may reset it.
Can also try going in the menus and rescanning for channels.
Posted on Apr 06, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: Philips Magnavox TP2784C TV always powers up to Channel 9
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
Posted on May 18, 2009
  • 11 Answers
SOURCE: access code forgotten need to unblock and restore channels
With the remote you can enter a code twice to reset (see pg. 15 of the manual below). It's possible that you can program a universal remote to use the buttons needed to reprogram.
http://www.usersmanualguide.com/philips/tv__4_3_-_tv_medium_20-24_inch/19ps50s
Posted on Apr 01, 2010
gopakumarg43
  • 74251 Answers
SOURCE: el tv dice blocked by
Hello
Your TV is locked I thinks.
Read this well before you proceed
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711,
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Posted on Dec 04, 2010
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
Reset code for channel access
Apr 06, 2009 | Philips Televison & Video
How to unlock phillips tv
Try this ..
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE"
Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Jan 31, 2009 | Televison & Video
Child Lock is on and I am second owner of tv with no code
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Smartlock code
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
for Philip sets is 0711, although it may say "Incorrect code" the first time
key on the remote. Enter the override code, and enter it a second time if it
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right
arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to
MASTER DISABLE and press the "right arrow" key so that it says "MASTER
Apr 03, 2008 | Televison & Video
Blocked channels
http://support.ttetech.com/RCATV/Assets /pdfs/27F530T_1620181B_IB_e-04.pdf this is link to owner's manual.....may have to get original remote......try mrremote.com....type in model# in search field...good success, Meder's Tv Service
Dec 13, 2007 | RCA 27F530T 27" TV
4 digit access code put in by previous owner. blocks some channels
use 0711 Hope that works. If you need more details I could email a portion of the service manual covering that procedure.
Nov 13, 2007 | Philips 27PT6441 27" TV
GE: 13" Model13GP341 vchip parental control locked
magnavoxes and phillips tv's uses overide codes .those of you who have either of the two tv sets try this code 0711 hope it works.
Nov 05, 2007 | Philips Magnavox 27MS343S 27" TV
Want to view all my tv channels
It sounds like a bad antenna but coming from a land of only 5 stations across the country it's hard to give an answer. BMW
Jun 03, 2006 | Sylvania 6427TE 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
