Question about Datalogic MOBILE MOBILE COMPUTER KYMAN 802.11B/G CCX V4 BLUETOOTH 128MB RAM/128MB FLASH 53 KEY... Portable Terminal
Connection not available
Sometime the Kyman doesn't connect using WiFi, It displays this error message "Connection not available". After some time or after reboot it can connect. The WiFi is ever available, the other terminals work normaly.
  • edacedpa Feb 22, 2012
    The terminal is new, if the antenna had broken the terminal should not work even after a reboot
My wireless icon displays as not connected even though I am currently surfing the net
Shut down the computer, unplug, remove battery, plug in, reboot.
Jan 19, 2013 | Toshiba Nb 305
Tip
How do I connect my iPod to My Network
<p>The iPod Touch is the only device in Apple's line of portable music devices with embedded networking capabilities. When you enable WiFi on your iPod Touch, the device scans the area for available networks and displays a list of results. From there you can connect your home network or Wi-Fi and use the Internet to email, instant messaging, Web browsing and other applications. <br /> <p> <br /> <p>1. Touch the "Settings" icon on the home screen of the iPod Touch. <br /> <p><br /> <p>2. Select "Wi-Fi" menu item. <br /> <p><br /> <p>3. Move the slider at the top of the window of the "Off" to "On" position. The phone will scan for nearby Wi-Fi networks.<br /> <p> <br /> <p>4. Tap the name of the network you connect to your iPod Touch. <br /> <p><br /> <p>5. Enter the password for the Wi-Fi network you selected with the keyboard on the screen. <br /> <p><br /> <p>6. Tap "Done" to connect to Wi-Fi network using the password you entered. When the Wi-Fi icon appears on the top screen of the iPod Touch, you'll know the connection is successful. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to solve DNS Failed Error in Samsung Cellular Phones?
<span><span><span><span>Hello and Welcome to FixYa!</span><br /><br />DNS Failed error is sometimes happens in Samsung Cellphones that while connecting to internet via WIFI<br /><br /><span style="font-weight: bold;">To solved it follow the given procedure:</span><br /></span> <ul> <li><span>Go to <span style="font-weight: bold;">Browser </span>of phone<span style="font-weight: bold;"><br /></span></span></li> <li><span>Then go <span style="font-weight: bold;">to Setting</span></span></li> <li><span>Then <span style="font-weight: bold;">Clear cache</span>, <span style="font-weight: bold;">Empty cookies and Delete history</span></span></li> <li><span>Now restart your <span style="font-weight: bold;">Samsung cellphone</span>, now connect to desire <span style="font-weight: bold;">wifi connection</span>, then browse after setting up your browser profile</span></li></ul>If it doesn't solved then contact to <span style="font-weight: bold;">Samsung Service providers</span> and consult with providers of WIFI connection, <span style="font-weight: bold;">But i hope it will work.</span></span><span><b><br /></b><span><b><br />Thank You For Using FixYa!<br /></b></span></span></span>
on Apr 28, 2011 | Cell Phones
SionEvery few days when switching on Luxor TV I get the message " No signal "
you did not mention that with which input you are using your tv. may be the input's cable is some times not connecting (bad wire) which sometime connects sometime does not. you try with replacing the wire & see if the problem is corrected.
Oct 13, 2011 | Televison & Video
Sylvania net book doesn't see available wireless
If it's not seeing wifi networks, more than likely, there is something wrong with the adapter. Try these steps:
1.) Look for a WIFI switch on the side or front of your laptop and make sure it is set to the ON position. 2.) Check Device Manager to make sure the driver is installed and working. If it's not, uninstall and reinstall. 3.) Go into Network Connections and make sure the Wireless Connection is set to Enable. 4.) If none of that works, perform a System Restore to a time when everything was working. 5.) If this doesn't work, you need a WIFI adapter replacement.
I hope this is helpful and thanks for using Fixya!
Sep 23, 2011 | Computers & Internet
Tip
The Best Way to Connect Your PS3 To the Internet/Wifi
<span>Instructions</span> <ol> <li> <p>Make sure your wireless Internet connection is active and at full strength. Unplug the PS3's Ethernet cable if it is plugged into the system.<br /></li> <li> <p>Turn on the Playstation 3 game console and select "Network Settings" under the "Settings" option in the main menu.<br /></li> <li> <p>Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.<br /></li> <li> <p>Select "Easy" on the next screen that asks what type of installation you want to use.<br /></li> <li> <p>Select "Wireless" when it asks you what type of Internet connection you have.<br /></li> <li> <p>Select "Scan" on the next screen.The system will search for all available Internet connections in the area.<br /></li> <li> <p>Select your home Internet connection when the screen pops up displaying the available Internet options. Select your security settings and enter your encryption key. Save your settings.<br /></li> <li> <p>Test the connection by selecting the "Test Connection" option. If the connection has been made, your network information will appear on the screen. <br /></li></ol>
on Jan 05, 2011 | Sony Playstation 3 (PS3) Console
In my pokemon white game i by accents erase nintendo wfc configuration and i forgot how to do it again so can you help me
To configure your internet options, go to the DS menu (the first screen you seen after turning of the DS). Select the System Settins option (the wrench icon), then scroll across 'till you find the Internet
choice. Select that and then Connection Settins. Choose Advanced Set Up then pick a connection.
If all connections display Set Up Complete , pick one and select the Connection Test. If there is an previously used Wifi hub or router within range, one of these connections should connect. If not, it will give you an error code that will help identify the problem.
If all the connections say None, then choose one and select Search For An Access Point. If all the connections are taken but none work, select one then choose Clear Settings. Then choose the connection that now says None and search for an access point.The DS will show a list of available access points; one should be your's. Select in and enter the security key and that should sort it. If your router or wifi hub isn't on the list, move closer to it or check it's working properly
Aug 24, 2011 | Nintendo DS Lite Console
How do I get my net book to use wifi? I usually connect to broadband and want to use wifi in my hotel? It does not show any available networks. Do I have my security settings too high, or do I just need to...
First of all you may want to decide to check out if the wifi connection is disabled or enabled.
If you go to system settings, in the network area you should be able to see if the wifi card is enabled. If is not enabled you may want to right click on the wifi icon connection and click on enable.
If this was the issue you know should be able to see and display all available networks in your area
Aug 03, 2011 | Acer Aspire One Netbook
Getting error dns fail, on email settings
This sometimes happens in Samsung Cellphones that while connecting to internet via WIFI, DNS failed
  • Go to browser
  • Then go to setting
  • Then clear cache, empty cookies and delete history
  • Now restart your Samsung S3653 cellphone, then connect to desire wifi connection, then browse after setting up your browser profile
If it doesn't solved then contact to Samsung Service providers and consult with providers of WIFI connection, But i hope it will work.
You can also see my TIP & TRICK regarding the same issue.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
May 21, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Hi I'm trying to use my desktop pc with ASUS P5Q3 Deluxe Wifi AP @n motherboards onboard WLAN as an Access Point to my Nokia X3-02 phone for WLAN. Would be nice to use same internet connection through...
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect to your phone
hope this helps
May 10, 2011 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Datalogic MOBILE MOBILE COMPUTER KYMAN 802.11B/G CCX V4 BLUETOOTH 128MB RAM/128MB FLASH 53 KEY... Portable Terminal Logo
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
