Question about Gateway M675 Notebook
DEAD GATEWAY M675
BATTERY LED RED, STANDBY LED BLUE. WILL NOT POWER UP.
    Problem Solver:
  • 7 Answers
Try running your laptop with the battery charge cord in but take battery out. If that doesnt work then the charge cord or charging hole might be shot. is the charge cord feel loose? like if u sneeze could it easily fall out? I like using humor.. If you take battery out run it or try to run it with the charge cord in and plugged in. If it works then that means it's ur battery. I had my laptop in the shop it was running hot. I used to call it my clothes iron.. nice hot and flattened my clothes for me. And thats all it did. I took it to the shop cause it wouldnt charge up, turn on.. made a lil noise as it tried for a second to beam up. Repair couldnt figure it out due to the fact it didnt start. It got back to me only to work for me this time. Then I lost it again. ANd spent some money modifying it with a different motherboard. One that doesnt fit. Oh ya im on that one right now... doesnt seem to be much of a clothes iron any more. But it serves the purpose. If you can fix it with a new battery or a practically inexpensive new charge cord then great.
Posted on Oct 10, 2009
  • 4 Answers
Its most probably a RAM gone bad. try taking out one of the ram modules and check to see which RAM slot or RAM module is acting up (mine was the ram slot 1 which suddenly stopped working). Or if your using pc3200 try replacing it with pc2700
also since u have opened up anyway try to do some cleaning
1. open up the fans and clean it- lots of dust and gunk in there
2. take off the cpu heatsink, clean it and put on a fresh coating of thermal paste
Posted on Jun 20, 2009
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Describe your Gateway M675 Laptop w/ Pentium4 Gateway M675 won't maintain a charge after charging and the display flicks from ac/dc until the battery is completely empty. Do I need a new battery or power...
Sounds like you need a new power adapter.The M675 needs the correct voltage constantly to work correctly.I'm using one right now and it does the same thing with the wrong adapter or a weak adapter(low voltage).M675 is a great laptop but with the 3.0ghz its got to get the power it needs especially when its under a heavy load.
Oct 26, 2010 | Gateway M675 Laptop
Gateway M675 will not boot. When I push the start
This might have something to do with the battery.
Have you tried to boot it up without the battery in it?
Regards.
Jul 03, 2010 | Gateway M675 Notebook
Blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Aug 28, 2009 | Gateway Computers & Internet
I dropped my laptop
any lights on the front display? (Also check the light on power adapter)
Dec 26, 2008 | Gateway M675 Notebook
Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Jul 01, 2008 | Gateway 400SD4 Notebook
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Gateway M675 Notebook Logo
170 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
