After twenty second the machine will get power off
The above is purchased last eight month back
  • yadayada
    yadayada Feb 22, 2012
    Something wrong with power supply?????
My Kindle was fine last night before last. It froze when I got ready to read it today. I tried rebooting it but when it came back on half the screen is visible the bottom half stayed frozen. Is there a...
It could be a hardware problem. Half a screen not working doesn't sound good to me. I have a PaperWhite Kindle. I had another Kindle I dropped and it came up like yours, with half a screen showing the picture and the other half the screen showing white. It's now a paper weight.
You can try a total reboot by holding down the power button for about twenty seconds. Mine hangs up every couple months and the touch screen stops responding and the reboot by holding down the power button for about twenty seconds fixes it every time. It takes a few minutes. You have to sit there and watch the slow progress bar fill in as it goes through the re-boot process.
If this doesn't work, you might try removing the back cover, disconnecting the battery. Letting it set for minute or so and then reconnect the battery, re-install the back cover and try a normal short-power button push first and if nothing happens, follow it with the long power button push.
Mar 01, 2015 | Tablets & eReaders
Dear Sir I have a technical error 41 and i dont know what to do.
When did the problem start on the printer
Thanks
proton
Aug 06, 2008 | Brother Office Equipment & Supplies
Charged too much on netflix account
Contact Netflix about this problem.
Feb 17, 2014 | Computers & Internet
XQG65-908E
Power up the machine and press TEMP, FABRIC SELECT, TEMP, FABRIC SELECT, in that order, within 30 seconds of powering up the machine, this will enter service mode and t01 will display on the control panel...
Hold in the delay button for 3 seconds, this should reset the codes....
If doing the above does not work after 3 attempts, there is a fault in the circuit relating to the fault code,,,(COMPONENT) good luck. the code is a stuck door. Hopefully you didn't try to pry it open.
May 03, 2017 | Watches
I bought three advent verona laptops for my children for Christmas 2010. In 8 months we had to replace the power supply cables 3 times on all machines. All of the laptops went back to PC world for over a...
I would recommend purchasing a universal laptop charger or adapter, they cost a little more and they should be better quality and last longer.
here is a great charger that works with almost any laptop out there, it is rated 120W and should have more than enough power for the machine - having larger capacity it should last much longer.
the manufacturer probably uses the cheatest possible charger for the machine this will probably have the power of two such adapters.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7008172&CatId=608
Feb 10, 2011 | Advent Netbook
Second time complete breakdown of engine ,camshaft chevy venture
youve already got way too much money in that van,
go buy somthing else !!!!!!
Apr 17, 2009 | 1997 Chevrolet Venture
DELL XPS M140
One of three things, 1- power supply, check your power supply with an ohm meter to see f it's getting the proper output to the machine. If the supply is starving the machine of power the charging system won't work to it's full potential. 2- the power management system on the motherboard, if this system isn't working properly it can divert power from the charging system. If it's just glitched then a bios download or chipset utility download will fix it, if it's malfunctioning, then motherboard replacement is the only option. 3- the battery itself, I have a Dell, and in the past two years, I've ordered two new batteries. The first held a great charge, more than three hours, but only lasted about eight months. The second only holds little more than an hour charge, but has lasted well. Batteries are just funny that way. Start with the power supply test.
Aug 23, 2008 | Dell Inspiron XPS M140 Notebook
F 70 code, and/or F 71 code
Washer --
The interface fried, probably lightning causing a power surge, a new one @ $152, + service call. Getting the part is a problem. It's 14 months old.
Our last washer was purchased second hand, we used it for over 20 years and it was still working when we replaced it.
paweb
Jul 22, 2008 | Whirlpool Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
