Question about Protron PLTV-32 Television
Sound not working right - Protron PLTV-32 Television
    Top Expert:
  • Protron Master
  • 75,304 Answers
Hello
Check the speaker first. If found OK, and you hear distorted sound, check the setting for sound, by its audio option menu.
If all are OK, and still the fault perists, the audio output section of your Tv should be troubleshooted.
Posted on Feb 22, 2012
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
No sound going to my right front speaker. I switched the center and right speakers to confirm that the speakers themselves are each working - just no sound being driven from the Sony HCD-S300 to the right...
Sounds like you may have a problem with the wires themselves. Perhaps you could sacrifice just a little integrity (literally not enough to notice) by simply tying into the center speaker with the right front wires. That way, at least they're all working.
Jan 17, 2010 | Electronics - Others
Horn doesn't work. It works when you electronicley
YOU HAVE TWO HORNS , ONE ON THE LEFT FRONT , THE LEFT ONE SOUNDS FOR YOUR ALARM. tHE RIGHT ONE AND THE LEFT SOUND SOUND WHEN YOU HONK YOU HORN. uNPLUG THE RIGHT HORN AND THE LEFT WILL WORK. REMOVE AND CLEAN THE RIGHT HORN AND IT MIGHT WORK OR REPLACE IT. i THINK THEY GET WATER IN THEM,
Nov 26, 2009 | 2004 GMC Envoy
Cannot get all speakers to work at once!!
It could be that every sound has its recording style, some record the sound to just left or right only(mono left or mono right) some has stereo, recorded on left and right. Some have induced additional sound that only surround sound is best at.
Or some base on signal strength, some cut or boost only to the level it is set to appear.
Apr 12, 2009 | Yamaha HTR-6030 Receiver
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
My shperex xbox 5.1 doesn't work for the right speakers
Unless your using the Optical and Coxal input you wont get 5.1 surround sound.
Mar 06, 2008 | Spherex Xbox 5.1 Surround Sound System...
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
