Question about Sony Cyber-Shot DSC-P8 Digital Camera
Flash My cameras flash is not working, and i cannot take photos without light. Please help The camera is still working well. Hope to hear from you soon Lenram Setu
How to repais flash
Posted on Jan 16, 2007
SOURCE:
DSC T90 digital cam While taking pictures of any small movement, the picture blurs or shakes. Please give me solution to fix this problem
To remove the blur from photos, you need to be in a place where there is enough light to have a fast shutter speed. Using the camera indoors without the flash on will usually result in blurry photos.
Try using the flash.
Holding the camera with two hands or even better, on a tripod, will help too.
Happy shooting!
Mar 06, 2011 | Sony Cyber-shot DSC-T90 Digital Camera
How do I set vivitar 5199 to take close up photos of artwork? The flash in each flash setting spoils the photos and indoor photos without the flash some up AVI
this is a cheaper camera so most likley will not be able to do so. these cameras have trouble focusing up close. but its worth a try. You can go on to www.youtube.com to find instruction on how to make a home made diffuser for your flash from a milk jug. Hope this helps -Richard
Dec 28, 2009 | Vivitar ViviCam 3710 Digital Camera
The flash will not work.
On the back you will see what looks like a little lighting bolt press key pad in that direction select flash, more you push it more choices.
If it is selected & not flashing you may have burnt out the flash bulb.:(
Hope this fixed ya! If you need more help comment back. Good Luck!
Please Rate.
Feb 19, 2009 | Olympus Camedia D-360L Digital Camera
Daytime photos are very white and has horizontal lines.
Hi!
If ever you haven't tried resetting the camera, please try it first. It's possible that you or somebody using the camera may have set something on the camera's setting to have this result ( this is based on my own experience :D ).
Anyway, here's how you reset your camera:
This will basically set the camera to default settings. If there is no hardware problem with the camera, this will correct the problem. However, if the problem persist after the reset , you may want to bring the camera in a service center for repair.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio Exilim EX-Z40 Digital Camera
Pink in the photos
maybe you use wrong white balance, test auto and manual white balance; if there is pink again then your camera have hard ware problem (CCD for exaple). I hope this helps...
Nov 01, 2008 | Canon PowerShot SD110 / IXUS IIs Digital...
My flash has stopped working
Hi
Unfortunately you will either need to replace the flash unit... or if you're unlucky the main PCB. I don't think you will be able to do anything without either of those parts.
I have made my living running a digital camera repair business for several years now, wish I had better news for you about your camera. If we can help with the repair let us know.
Good luck: Darntoothysam com
Thomas
Sep 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Help
charging flash means then the camera is charging the flash light,, thats not a problem,, just wait for a couple of min, , and then take photos,, hope i helped ya
Jul 05, 2008 | HP Photosmart R707 Digital Camera
E:91:01 and Fash is not working
Gentlemen,
Please initialize your cyber-shot and this option is available in camera Menu. Hope this would solve problem.
May 15, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Olympus Camedia C-4000 Flash Problems.. Help Please!
The flash is malfunctioning and causing the camera to not work, the flashing lights in the viewfinder is the camera indicating the malfunction. Most likely it is a board that needs repair and that'll cost a flat rate minimum $160 from OLY.
Feb 27, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
My camera c633 takes photos but flash wont work????even with new batt???
It is eathe the bulb or the flash circuit. if you are going to fix it yourself watch out for the flash compasitor. If you are going to send it in watch the cost. It sould be fairly cheap to have fixed.
Dec 31, 2007 | Kodak EasyShare C633 Digital Camera
Sony Cyber-Shot DSC-P8 Digital Camera Logo
83 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
