Question about Car Audio & Video
How to fix a 2004 chrysler sebring stereo wiring shortage
  • Jake O'hair Feb 22, 2012
    Is it a broken wire or what are the symptoms?
  • 1596 Answers
SOURCE: 2004 chrysler sebring grinding noise
Check CV Joints and AXEL BEARINGS This is Common
Posted on Dec 09, 2009
01fordeb
  • 1033 Answers
SOURCE: oil sending unit on 2004 chrysler sebring V6
Should be located close to the oil filter. It will screw in like a spark plug. It has a harness plug. Easy to change, save yourself $70 in labor. You will need a fairly large wrench to remove
Posted on Jan 03, 2010
SOURCE: 1998 Chrysler Sebring Car Stereo Radio Wiring
i have a 1997 chrysler sebring LX Coupe and i can't figure this out i got a aftermarket jvc cd player and i got the wiring harness for my car chrysler and i am not getting any sound please help me
Posted on Apr 01, 2010
jlisagearhea
  • 412 Answers
SOURCE: Where is the fuel filter located on a 2004 Chrysler Sebring Sedan
Some of the Sebrings have two filters(one is called a sock).The sock(which all sebrings have) is located in the fuel tank itself on the pump module.If this model is the JXI then the external filter is located on the belly of the car between the tank and drivers rear seat. I hope I could help!!!
Posted on Apr 29, 2010
ZJLimited
  • 17970 Answers
SOURCE: 1999 Chrysler Sebring Convertible code P1495. I
Code 1495 = Leak Detection Pump Solenoid Circuit
Remove the connector from the solenoid (should be on the back wall, just to the drivers side of the air-hat). You will have the solenoid to check and the harness. What you want to measure is the voltage coming from the harness and the resistance of the solenoid.
Turn the key to the "ON" position but do not start the motor; the voltage at the connector should be at least 10V or more,.now, check the resistance of the solenoid (should be around 35 ohms).
Hope helps.
Posted on Jun 03, 2010
The easiest way to take off a water pump for 2004 Chrysler Sebring
Take it to a garage and say "put a new water pump in this for me".
2004 Chrysler Sebring 2.7Ltr. Water Pump Replacement ...
z? 29:29 https://www.youtube.com/watch?v=ebeXcNmBnnE Sep 19, 2015 - Uploaded by Paul Veltum In this video I'll walk you through replacing the water pump on this 2004 Chrysler Sebring with it's 2.7 ...
2004 Chrysler Sebring Timing Belt Water Pump Before 90K ...
2q==? 13:03 https://www.youtube.com/watch?v=UQHRa28sRkY Nov 25, 2012 - Uploaded by Mastermind Denver This video shows why we at Mastermind Enterprises Auto Repair Shop in Denver recommend replacing the ...
WATER PUMP REPLACEMENT IN CHRYSLER 2.7L ...
9k=? 4:52 https://www.youtube.com/watch?v=z_QrXR2jcb8 Mar 7, 2014 - Uploaded by kzguy2 2008 Dodge Charger 2.7l was in need of a new water pump due to it leaking. ... 2004 Chrysler Sebring 2 ...
2004 chrysler sebring water pump weep hole inspection ...
2q==? 0:15 https://www.youtube.com/watch?v=wzqHaQ40doQ Feb 26, 2014 - Uploaded by Graeme Tolton 2004 chrysler sebring water pump weep hole inspection with borescope. ... 2004 Chrysler Sebring 2.7Ltr ...
Chrysler 2.7L Water Pump Installation Problems - YouTube
9k=? 3:30 https://www.youtube.com/watch?v=h5_VFJ1gCpI Nov 19, 2014 - Uploaded by South Main Auto Repair When I installed this water pump on the 2006 Chrysler Sebring 2.7L I ran into a ... 2004 Chrysler Sebring 2 ...
Feb 15, 2016 | Chrysler Cars & Trucks
Ya i need a 2002 sebring convertable spearker/ stereo wiring diagram pllease
2002 Chrysler Sebring Car Radio Installation Instructions
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
24 7 Locksmith Tonawanda NY 716 200 1030 Emergency Locksmith
Jul 23, 2015 | Chrysler Sebring Cars & Trucks
Need wiring diagram for stereo 1997 sebring
Hi there:
I suggest to check this on 1997 Chrysler Sebring Convertible Car Radio Wiring Guide...
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black/Yellow
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Green/Yellow
Car Audio Front Speakers Size: 6 1/2" Speakers
Car Audio Front Speakers Location: Doors
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: 6" x 9" Speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 07, 2012 | 1997 Chrysler Sebring
Need wiring diagram for stereo or wire color coding
Hi there:
1997 Chrysler Sebring Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red
Radio Ignition Switched 12V+ Wire: Blue
Radio Illumination Dimmer Wire: Green/Yellow
Left Front Speaker Wire (+): White/Blue
Left Front Speaker Wire (-): Black/Blue
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Black/Red
Left Rear Speaker Wire (+): Yellow/Blue
Left Rear Speaker Wire (-): Gray/Blue
Right Rear Speaker Wire (+): Yellow/Red
Right Rear Speaker Wire (-): Gray/Red
Nov 08, 2012 | 1997 Chrysler Sebring
Nov 11, 2009 | 1998 Chrysler Sebring
1999 chrysler sebring, transmission doesnt shift
find out why the light is on and fix it. This will most likely be a trans wiring issue that the light is on for.
Jul 11, 2009 | 2004 Chrysler Sebring
2004 Chrysler Sebring- Left turn signal problems
Sounds like a short in the wiring or fuse panel. As new as it is, I would suggest a mechanic as troubleshooting wiring in newer cars is not only difficult, but also dangerous. Many a shade-tree mechanic has set off the airbags that way!
Apr 14, 2009 | 2004 Chrysler Sebring
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
