Question about Sony VPL-CS7 Multimedia Projector
SONY VPL-CS7 LENS EMITS YELLOW RAYS HENCE NOT CLEAR
  • Ernesto Jul 17, 2013
    yo tengo el mismo problema alguien que tenga alguna solucion
Yo tengo el mismo problema alguien que tenga alguna solucion???
Posted on Jul 17, 2013
    yo tengo el mismo problema alguien que tenga alguna solucion???
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Can only view image in a very dark room.
If you need it you can get the user manual on this link; http://esupport.sony.com/perl/model-documents.pl?mdl=VPLCS7 check page 29 - brightness setting adjustment just to be sure this is not the problem. check page 36 - lamp mode - try high if not already set on it. Check page 42 - cleaning the filter - this can stop the projector functioning properly, but i don't think it's the problem in this case If the image is being projected exactly as normal, apart from the brightness, then the problem is most likely a failing bulb, despite the low hour count. Just possibly (but unlikely)there is a power supply problem that is not feeding enough voltage to the lamp, only way to tell for sure would be to either get a meter on the lamp terminals, which looks practically impossible with the lamp in place, (possibly will give a reading without the lamp, but the terminals may be disconnected from the power when the lamp is removed), or replace the lamp. Are there any flashing lights or error messages at all, does the projector seem hotter than usual, is the fan running as normal? could you actually see any error messages on the projected image if they were there? try really hard to read them if you think there could be something there. Try a different input source, unlikely problem but possible. Especially in smoky environments the lens can get quite a thick layer of grime on the outside - easily cleaned off gently with some vinegar and soft paper towel/soft cloth. This made enough difference on a similar one in a bar near me to give them 3 months more with the same bulb. Worth a try. If you need to source a bulb you need Sony LMP-E180 there appear to be no cheaper substitutes, you can get one direct from sony uk on this link; http://www.sony.co.uk/view/ShowArticle.action?articlesection=1&article=1158155174490&site=odw_en_GB These lamps are often cheaper from the US even with postage, if you can find a dealer who will send you one, check this link for some ideas; http://www1.epinions.com/t-sony-lmpe180 I got a lamp for a similar sony projector sent to spain a few months ago, saving about $280!!! - I'll keep trying to find the details of the company I used, no luck at the minute. Hope this helps, post back if you have any more info :)
Posted on Jul 04, 2007
rockitman187
  • 2559 Answers
SOURCE: Please replace the lamp
On your remote,push these 4 buttons in this order.
RESET < > ENTER
Posted on Jan 12, 2009
projdoc
  • 2236 Answers
SOURCE: my projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Posted on Dec 08, 2009
Testimonial: "Thanks very much for the help. "
  • 1623 Answers
SOURCE: someone from my work has
you shouldnt need a dvd to install the projector all you need to do is enable the external monitor interface on your laptop. User manual can be found here
http://www.aboutprojectors.com/pdf/sony-vpl-cs7-manual.pdf
Posted on May 30, 2011
Noticed a yellow hue in the centre of the image projected by BOTH of my second-hand Sony VPL PX40's.
Bit of a common problem with Sony projectors of the era that they often had problems with fading and/or cracking of one or more the LCD panels - especially the blue ones for some reason, leading to the type of problem you are experiencing. No point in swapping components either as they will both have similar faults - although replacing an LCD in a video projector is almost impossible without the manufacturers jigs to mechanically align them afterwards anyway...
Mar 25, 2014 | Sony VPL PX40 Multimedia Projector
Jun 30, 2007 | Sony VPL-CS7 VPL-CS7 MMPROJ XGA 1800LUMEN...
My sony VPL-CS7 projector lamp goes of very minutes
1,if the lamp can be lit for 1minute,so the lamp is ok
it seems that the lamp ballast or mother board is defective.pls check them
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 03, 2014 | Sony VPL-CS7 Multimedia Projector
How to reset sony projector vpl-es2 without remote control cause the panel key is lock?
Turn the projector on and leave in standby mode. To do this press the power on button for 10 seconds until the projector comes on.
To unlock the main panel keys, press the MENU button for 10 seconds.
Aug 05, 2011 | Sony VPL-CS7 Multimedia Projector
Someone from my work has written instructions to connect the sony data projector vpl-cs7 to our laptop. it says to insert the dvd. I do not have the dvd so am keen to download it but i don't know what...
May 30, 2011 | Sony VPL-CS7 Multimedia Projector
How can we resate the lamp hurs
press key Reset,Right Arrow,Left Arrow then Enter and restart projector.Lamp hour show "0"
Feb 17, 2010 | Sony VPL-CS7 Multimedia Projector
With the vpl cs 7 can two computers be run off the projector at the same time as the projector has two ports.
this manual will tell you if you can or not but with most projectors it will not show both the computers at once but you could have both pluged in and switch between computers,http://www.fixya.com/support/p201884-sony_vpl_cs7_multimedia_projector/manual-16017
Dec 14, 2009 | Sony VPL-CS7 Multimedia Projector
Lamp/cover light flashes orange
could be need new lamp
very expensive!!
how old is the tv?
is this the first lamp?
usually get 10000 hours use out of one lamp
Jun 01, 2009 | Televison & Video
RESET < > ENTER
Jan 12, 2009 | Sony VPL-CS7 Multimedia Projector
Sony VPL-CS7 Multimedia Projector Logo
103 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
