Question about Refrigerators
My baumatic bl18a larder fridge runs all of the time but isn't cold inside
Has been working fine for the last few years but just noticed that the compressor is running all of the time and the inside is not cold. Have tried switching it off for a while and then on again and also adjusting the temp control knob but no improvement
  • 1462 Answers
SOURCE: which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Posted on Apr 19, 2007
  • 833 Answers
SOURCE: larder fridge is icing up
There are a couple of reasons for ice-up. Let's check them:
  1. First, clean any coils in the back or underneath completely.
  2. Defrost the unit thoroughly. This could take a while and may lead to a quart/liter of water coming out. Usually this takes a day or so but can be sped up with a hair dryer or other heat source...electricity and water DON'T mix!
  3. Make sure all circulation vents in the box are unblocked.
  4. Start the unit. Watch the larger of the two pipes coming to the compressor...that big black thing under the fridge. It should frost up and then either dry out or stay wet after a half hour or so. If the frost stays on while the compressor is running, you are short on refrigerant gas...you'll need to get additional gas added.
Note: minimize the amount of uncovered liquids, the amount of time the door stays open and clean off dirt on door gaskets (be sure they fit properly by sliding a sheet of paper between the gasket and the frame of the fridge...it should move with some snubbing.
Posted on Jul 23, 2008
  • 1462 Answers
SOURCE: Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
  • 435 Answers
SOURCE: I have a fitted kitchen
Could you please tell us where you are from and any model number if possible ?
thanks,
Posted on Sep 30, 2008
tborn6
  • 700 Answers
SOURCE: larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Posted on Jan 13, 2009
My Baumatic larder fridge won't go cold the fan and the compressor is working but the temp won't go below 16 degrees
Check to see if there is ice built up around the door preventing it from closing and sealing properly. This can happen if the door isn't closed all the way at times.
Jan 26, 2013 | Refrigerators
Fridge isn't staying cold, the freezer works OK.
if your freezer is working fine and you hear your compressor running you could have a frozen drain tube or more than likely the evaperator motor fan has failed.this is the fan that circulates the cold air from freezer throughout frigerator.what kind of unit is it?side by side or top mount freezer or what?let me know
Dec 25, 2012 | Refrigerators
Larder fridge light on but not getting cold
Check condenser clean and warm. If too hot, may be fan not running, if too cool, compressor not pumping or short of gas
Aug 07, 2012 | Frigidaire Refrigerators
Nt side by side fridge freezer not freezing
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps.
May 22, 2012 | Hotpoint Refrigerators
I have a Baumatic fridge/freezer the fridge is not cold even on maximum setting the model number is BRB2713 please can you suggest what the problem might be
First check the simple things. Check to condenser grill and make sure the air flow is not blocked by lint, etc. And then make sure that nothing is blocking the cooling tubes between the freezer and refrigerator. I think the Baumatic has a fan pulling the cold air up from the freezer compartment into the fridge, if that isn't working, the freezer would be fine, but the fridge would be to warm.
Jun 03, 2011 | Baumatic BR22 8A Bottom Freezer...
Larder fridge running far too cold
I was told that it ispossible for a snall pin in the thermostat to stick and that vigorously turning the knob up ad down a few times might well unstick the pin
Tried it and it worked!
Jan 03, 2009 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
