Question about Car Audio & Video
What color is the power antenna wire on 2005 f250
5 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: AFTERMARKET REPLACEMENT FOR AUTO ANTENNA
sounds simple
placement of antenna is important this will determine which wires to use
most antenas are in the trunk of vehicle with a wire clip to connect or disconnect
tools needed
test light
find your wire clip running from old antena this will be where test light will be used one side of clip is full powered the other is key powered find good ground tip the test light on first prong light stays on this is full power other will be key powered
now your looking for the simple color wires ok on the back of your sterio there is an atenna wire which is blue this will power on only when sterio is on the other wire
you use test light to find without key in take your test light and find a permannent powered full on wire hot supply then connect antenna into these 2 things
at top the reason i mentioned this is cause the old power antena you can find the right leads in the trunk area where new antenna going to be placed with the test light you might need a second person to help you testing wires you in the back and them in the front turning the key on when you need it it makes things simpler with 2 people
i hope this helped you in your quest for knowledge
Posted on Jun 01, 2008
  • 162 Answers
SOURCE: what is the color and location on the tach wire on
Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the green/white tach wire within the harness
Posted on Apr 04, 2010
  • 8 Answers
SOURCE: color of power wire on 2005 handlebar controls
wire is white with a black strip will be your hot
Posted on Apr 12, 2010
saailer
  • 1868 Answers
SOURCE: What color wires lead to the IAT sensor on a 2005
Hello! The Intake Air Temperature (IAT) sensor has the following wire colors...Gray/Red and Gray...
Guru...Saailer
Posted on Jan 04, 2011
Radio wiring diagram
lost my post. 1 more time. im logged in to alldata.com so can you....!!
there were 6 systems. (orig)
how many speakers.? 4 or 6, with CD and with out, and with external amp and with out,, all have different colors, for antenna motor.
on one setup is wire color P-L (purple,+ ?) (no amp)
pin 9 on radio, marked amp in schematic. and is 8 speakers.
the amp external , used the red wire pin1, not 13 red beep
the red power this amp and antenna motor,
log in and look?
Jan 04, 2014 | 1993 Toyota Camry V6
Installed an aftermarket pioneer stereo in my 2005 Montana. I bought the recommended installation kit, antenna adapter, and wire harness kit. Stereo will not power up. What do I need to do? Please help...
There always the possibility that your Pioneer stereo was DOA but I recommend going back over your installation checking especially for functional matching of the adapter wires. The colors may differ
Apr 21, 2013 | 2005 Pontiac Montana
What color wires lead to the IAT sensor on a 2005 ford f250 6.0 powerstroke?
Guru...Saailer
Jan 04, 2011 | 2005 Ford F 250 Super Duty
Radio wireing need the wire color codes to match
Check this...
1992 Ford F250 Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Hope this helped (remember comment and rated this post).
May 11, 2010 | 1992 Ford F250
What is the color and location on the tach wire on a 2005 ford f250 diesel
Apr 04, 2010 | 2005 Ford F 250 Super Duty
What wire do you use to hook up the power antenna wire to; i am changing from factory radio to a purchased radio but i have a power antenna wire but not a matching wire on the radio
you are not putting a factor radio it not have that same colors . look at the wire diagram to tell which color to hook to car side
Feb 25, 2010 | 1996 Cadillac DeVille
95 ford f250 trailer wiring trouble what does each wire work and what color
The basic 4-flat trailer wiring colors are as follows.
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights and White-Ground
7-way trailer wiring colors are as follows.
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights, White-Ground, Red or Black-auxiliary power, Blue-Trailer Brakes and Purple-Reverse lights
Jan 15, 2010 | 1995 Ford F250
Stereo wiring diagram 2003 f250 deisel
2003 Ford F250 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger: Blue
Left Front Speaker Positive Wire (+): Light Blue/White
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): Dark Green
Right Front Speaker Negative Wire (-): White/Light Green
Left Rear Speaker Positive Wire (+): Tan/Yellow
Left Rear Speaker Negative Wire (-): Gray/Light Blue
Right Rear Speaker Positive Wire (+): Brown/Pink
Right Rear Speaker Negative Wire (-): Orange/Red
Nov 17, 2009 | Car Audio & Video
sounds simple
tools needed
test light
May 31, 2008 | 1990 Toyota Celica
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
