Question about HEWLETT-PACKARD Hewlett Packard HP Pavilion Laptop with AMD Turion II Ultra DualCore Mobile Processor Espresso Black (dv73165dx) PC Notebook
CANT LOG IN TO COMPUTER AND HAVE NO PASSWORD RESET DISK
Forgot password for adminstrator account?
Forgot aministrator password? You can use Smartkey Windows Password Recovery to reset administrator password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Jul 12, 2012 | Acer Computers & Internet
Tip
How to create a password recovery disk
How to create a password reset disk
To create a password reset disk for your local user account, use one of the following methods.
Requirements
The following methods require one blank, formatted floppy disk.
Use a computer administrator account
If you logged on to the computer by using an administrator account, follow these steps to create a password reset disk for a user account:
  1. Click Start, and then click Control Panel.
  2. In Control Panel, click User Accounts.
  3. In the User Accounts pane, click the account that you want to work with.
  4. Under Related Tasks, click Prevent a forgotten password to start the Forgotten Password Wizard, and then click Next.
  5. Insert a blank, formatted disk into drive A, and then click Next.
  6. In the Current user account password box, type the password for the user account that you chose in step 3, and then click Next.
    Note If the user account does not have a password, do not type a password in the Current user account password box.
    The Forgotten Password Wizard creates the disk.
  7. When the Progress bar reaches 100% complete, click Next, and then click Finish.
  8. Remove and then label the password reset disk. Store the disk in a safe place.
Use a limited account
If you logged on to the computer by using a limited account, follow these steps to create a password reset disk for your user account:
  2. Under Pick a category, click User Accounts.
  3. Under Related Tasks, click Prevent a forgotten password to start the Forgotten Password Wizard.
  4. Click Next.
  6. In the Current user account password box, type your password, and then click Next.
    Note If your user account does not have a password, do not type a password in the Current user account password box.
How to log on to the computer by using a password reset disk
If you forget your password, you can log on to the computer by using a new password that you create by using the Password Reset Wizard and your password reset disk. To do this, follow these steps:
  1. On the Windows XP logon screen, click the user name that you want to use. The Type your password box appears. Press ENTER or click the right-arrow button. You receive the following error message: Did you forget your password?
    You can click the "?" button to see your password hint.
    Or you can use your password reset disk.
    Please type your password again.
    Be sure to use the correct uppercase and lowercase letters.
  2. Click use your password reset disk. The Password Reset Wizard starts. The Password Reset Wizard permits you to create a new password for your user account.
  3. Click Next.
  4. Insert the password reset disk into drive A, and then click Next.
  5. Type a new password in the Type a new password box.
  6. Type the same password in the Type the password again to confirm box.
  7. In the Type a new password hint box, type a hint to remind you of your password if you forget the new password.
    Note This hint is visible to anyone who tries to log on to the computer by using your user account.
  8. Click Next, and then click Finish. The Password Reset Wizard quits, and you return to the Windows XP logon screen.
    Note The password reset disk is automatically updated with the new password information. You do not have to create a new password reset disk.
  9. Type your new password in the Type your password box, and then click the right-arrow button to log on to the computer.
Troubleshooting
  • The password reset disk cannot be used to reset the password on another computer.
    The password reset disk that you create can only be used with the computer it was created on. For example, if you have two Windows XP-based computers that have the same user names and passwords, a password reset disk that you create on the first computer cannot be used to reset the password on the second computer.
  • The password reset disk contains sensitive information.
    Other users may be able to use the password reset disk to gain access to your computer. For this reason, store this disk in a safe and secure location.
on Jun 21, 2011 | Computers & Internet
Tip
Reset Windows 7 Password With Own Created Reset Disk
How to Reset Windows 7 Password
It is easy for you to create a password on Windows 7 to protect computer data. At often as you might forget Windows 7 password, which may result in serious data loss. In reality, forgetting Windows 7 password is not a big problem as long as you create a Windows 7 password reset disk in advance. A Windows 7 password reset disk can help you easily reset Windows 7 password when you are locked out of computer.
Part one: Create Windows 7 password reset disk
Before creating the password reset disk, please insert a USB flash drive or floppy disk in your computer.
1.Click Start button to select Control Panel.
2.Click on User Accounts and Family Safety, and then click on User Accounts.
3.Click on Create a password reset disk on the left of the following screen.
4.Click Next when the forgotten password wizard welcome screen appears.
5.Select your target device to create the Windows 7 password reset disk.
6.Type current user account password.
7.Click Ok when the password reset disk is created.
8.Click Finish when the completing screen comes up.
When the Windows 7 password reset disk is created, a file named userkey.psw will appear on your USB flash drive. Please remember to place the USB flash drive or the file in a safe place. Anyone can use it to reset your Windows password with it if he can get physical access to it.
Part two: Reset Windows 7 password with password reset disk
When you forgot Windows 7 password and locked out of computer, you can take out of the password reset disk to reset Windows password. Plug your password reset disk in computer, and then follow the below steps for Windows 7 password reset.
1. Log on your computer with the target Windows account.
2. Enter a wrong password in the welcome screen password box, and hit Enter.
3. Click OK when the message that the user name or password is incorrect comes up.
4. Click on Reset password on the following screen.
5. Click Next when password reset wizard welcome screen appears.
6. Select the target password reset disk and enter Next.
7. Enter and confirm your new Windows password and click Next.
8. Click Finish to close the wizard.
9. Log on Windows 7 with the newly reset password.
If you forgot to create Windows 7 password reset disk before locked out of computer
A windows 7 password reset disk can really save you a lot of trouble when you forgot Windows 7 password and locked out of computer. So don't forget a password reset disk before locked out of computer. If you forget to create Windows 7 password reset disk, you can use Windows Password Breaker Professional to help you reset lost Windows 7 password. This safe and reliable Windows password recovery software allows you to burn a bootable CD/DVD or USB flash drive to rest lost passwords for Windows 7/Vista/XP/NT and Windows Server 2008/2005/2000. You can log on your computer again within 5 minutes with this tool.
on Oct 29, 2010 | Computers & Internet
I cant log in because i forgot my password ?
The following ways can help to reset or recover lost windows password in a few steps.
1. Reset windows password with reset disk.
  1. If you enter the wrong password when you attempt to log on, Windows displays a message that the password is incorrect. Click OK to close the message.
  2. Click Reset password, and then insert your password reset disk or USB flash drive.
  3. Follow the steps in the Password Reset wizard to create a new password.
  4. Log on with the new password. If you forget your password again, you can use the same password reset disk. You don't need to make a new one.
2. Reset windows password with a Windows Password Reset software.
Step 1: Download and install Spower Windows Password Reset.
Step 2: Create a CD/DVD or USB password reset boot disk with SWPR.
Step 3: Boot your computer from password reset boot disk.
Step 4: Recover the forgotten password for administrator account.
Mar 26, 2011 | Toshiba Satellite Pro L300 Notebook
How to reset password on my compaq computer!
Start pc in "Safe Mode With Command Prompt" When windows starts, type your log in name in the dos window with an asterisk. For example ( john * ) but with out the (). It will prompt for a new password. Reboot and Bam your in. If you cant remember a log in name exactly as it is, type in ( net users ) and hit enter.
Jun 13, 2010 | Compaq Digital PC 3100 PC Desktop
Tip
How to log on to Windows XP if you forget your password or if your password...
Introduction:
If you forget your Windows password or if your password expires, you
must reset your password before you can log on to your computer. This
article contains two methods that you can try to reset your password
so that you can log on to your computer again. These steps only work
if you have previously created a password reset disk for the computer,
or if you can log on as an administrator to assign a new password to
your account.
If you do not have a reset disk or cannot log on as an administrator,
unfortunately, you may have to reinstall Windows XP and all other
programs that were installed on the computer before you can use the
computer again. This is for security. Without these safeguards, anyone
could reset a password to anyone else's computer and gain access to
private information.
This article is intended for a beginning to intermediate computer user.
You may find it easier to follow the steps if you print this article first.
More Information:
Reset forgotten or expired password
If you forget your password or if your password expires, there are two
methods that you can use to log on to create a new password. One
method is to use a password reset disk, if you have created one. By
using the password reset disk, you can recover your user account and
your personalized computer settings. Another method is to log on using
the administrator account to delete the forgotten password and then to
If you have a password reset disk, go to method 1. If you do not have
a reset disk, go to method 2. The instructions guide you through each
step and help you verify that the problem is resolved.
on Mar 28, 2010 | Computers & Internet
I forgot the password to log
If you forget your Windows password or if your password expires, you must reset your password before you can log on to your computer. This article contains two methods that you can try to reset your password so that you can log on to your computer again. These steps only work if you have previously created a password reset disk for the computer, or if you can log on as an administrator to assign a new password to your account.
If you do not have a reset disk or cannot log on as an administrator, unfortunately, you may have to reinstall Windows XP and all other programs that were installed on the computer before you can use the computer again. This is for security. Without these safeguards, anyone could reset a password to anyone else's computer and gain access to private information.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | IBM ThinkPad T21 2648 Notebook
I lost my log in password
If you forget your Windows password or if your password expires, you must reset your password before you can log on to your computer. This article contains two methods that you can try to reset your password so that you can log on to your computer2_bing.gif again. These steps only work if you have previously created a password reset disk for the computer, or if you can log on as an administrator to assign a new password to your account.
Thanks.
Apr 30, 2010 | ASUS Eee 4G Notebook
Forgot password
Apr 29, 2010 | HP 530 Notebook PC
I type in my password and my computer tells me that i cant log in
I have had this happen, sometimes things get screwy and it just won't recognize your correct password. You need to restart your computer from the original disk. Put the disk in, shut down, restart by holding down the C key. At the top of the screen there will be an installer menu item, click it and then click Reset Password. Then restart your computer and you should be good to go.
Jul 05, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
HEWLETT-PACKARD Hewlett Packard HP Pavilion Laptop with AMD Turion II Ultra DualCore Mobile Processor Espresso Black (dv73165dx) PC Notebook Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
