I have a blu ray DVD player, cable high speed Internet with router, and just purchased Samsung link stick wireless LAN adapter. Attempted to connect to net, player acknowledged my network but was unable to connect. What do I need to do
ghassun
  • 499 Answers
SOURCE: Unable to connect wireless network to Blu-Ray player
TRY TO OPEN THESE PORTS VIA FIREWALL OF UR WINDOWS ALSO FOR UR ROUTER
Posted on Jun 08, 2009
  • 19 Answers
SOURCE: Samsung bd-p1600 wireless connection to 2wire 1800HG router
Check CNET Samsung forum. There are several posts with the same problem. A couple solutions and basic confirmation that Samsungs newest fireware is bad. I wish their support helpdesk would realize that instead of telling me to contact my router support.
Posted on Oct 26, 2009
  • 10 Answers
SOURCE: Dynex router blocks connection of Samsung BD-P1600 Blu-Ray to Net
I'm not familiar with that particular router, but all of them are about the same. You can go in and edit firewall settings to allow a particular IP address to have access. Don't disable the firewall completely, just set it to allow that I.P address to have full access.
Posted on Nov 15, 2009
gymowner
  • 679 Answers
SOURCE: Samsung WIS09ABGN LinkStick Wireless LAN Adapter
Do me a favor first, shut everything down and unplug it all the tv the stick and the router and get back to me, thanks, I don't want you to spend money if there is no need,
Gym
Posted on May 23, 2010
  • 825 Answers
SOURCE: When trying to connect to
the usb wifi adapter is supposed to be plugged in only in the computer and not in the blu ray players...
Posted on Aug 22, 2010
Can't connect my blu=ray dvd to my wireless internet
Please clarify your model number. If you have the DMP-BD60, it only has wired networking capabilities. A USB wi-fi dongle will not work (the USB port is only for storage devices). If you are connecting it to a wired port on a wireless bridge (switch) or directly to your wireless router and having trouble with the connection, check your cables and that your network is up. Next check that you have not restricted the number of devices allowed to connect to the router. There are ways to limit the number of IP addresses in the router setup. If you allowed 4 addresses and the blu-ray player will be number 5, you need to adjust the settings for your router.
Please add a comment with the model number if you are using a different blu-ray player. I hope this helps.
May 05, 2012 | Televison & Video
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Do I need to get an adapter or anything to connect my blu ray to my internet? I already have the ethernet/LAN cable but connection keeps failing
You shouldn't need an adapter. Are you plugging it directly into the wall or into a router? It's possible something to do with your router settings is causing the connection to have problems. You may want to consult the manual to your router if you are using one.
Feb 28, 2011 | Sharp BD-HP24U Blu-Ray Player
Hello, the 4 LAN ports on my D-Link router, model DIR-615, don't seem to be working. The lights are not coming on. This is the 1st time I'm trying to use those LAN ports so that I can connect my new...
It probably is your router that is the problem.
Disconnect its AC power, and reconnect it, to "reset" the router.
Also, try connecting your Blu-Ray player directly to your cable-modem (or DSL-modem), bypassing your router. Turn the modem off, and then turn on, and then turn your Blu-Ray player on, and it should be able to connect to the Internet (and NetFlix).
Try a different router.
Oct 17, 2010 | D-Link AirPlus DI-524 Wireless Router
I want to connect a wireless internet to my samsung blu ray BD P1500, how shoudl I do?
Unfortunately, this player has to use a wired network. (The Samsung WIS09 Wireless USB Adaptor is not compatible with the BD-P1500; it is compatible with the P1600.) Most wireless routers have a 4-port switch built in. If you can position your router in a place where the computers in your network can find the signal but gives you an easy wire run, do so with RJ-45 Cat5e or Cat 6 cable. Otherwise, you will need to run cable in the walls, in an attic or in a basement/crawlspace or use a second unit (wireless router (that can work as a switch), wireless switch or bridge with RJ-45 ports) to connect the TV to the primary router. Running cables will depend on your home, this can be easy or hard.
I hope this helps.
(In general I prefer wired networks. There is much less trouble-shooting for signal loss. Adding an extra switch adds to the issue.)
Sep 06, 2010 | Samsung BD-P1500 Blu-Ray Player
Gym
May 18, 2010 | Samsung WIS09ABGN (8808993304486)...
Blu ray want connect to the internet
You have to buy a Samsung wireless adapter in order to use a wireless conection..look up your player at www.avsforums.com for any and all questions and answers.
Nov 14, 2009 | Samsung BD-P1500 Blu-Ray Player
Blu-ray player no longer connects to network to view Netflix
First check the securty settings on the router. Most of these units use 64 bit/128bit configurations. Just this little change can make things work. Try changeing the security to 64/bit encription.
Let me know how this does.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 09, 2009 | Samsung BD-P1600 Blu-ray Disc Player
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
