Question about Advent HT3061A TV
Red light indicate the power is on but the tv screen is still black please help me how can I fix this problem.
How to fix a lg tv 47inch with black screen no pictur 47LB5900 model
The red light merely indicates power is getting to your TV. There may be an open internal fuse or power supply failure.
Jul 17, 2016 | LG Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
Hallo. I have a Prosonic TV type LC-27M65 that will not switch on. The red control light for remote is on. The yellow light indicator for current is off. Although TV is connected to net for power, the...
It is possible that your TV has encountered a fault in the power section possible a short in the drive power section. hence on powering the power sully working OK is switching the secondary power to the main board but this short is taking in more current than specified. the feedback of this is read by the SM unit to shut off the power to protect the supply. Hence you will have to probe into the sections to find this short, perhaps a HT drive transistor or the HT transformer or capacitors. If will be easier to check the continuity with a meter. Please attemptt only if familiar otherwise take help. Disconnection of the shorting section will switch the power, replace teh component in question. Hope you try. Good day
Aug 16, 2010 | Prosonic Televison & Video
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Help fix screen t.v.
What red light are you referring to? If you are talking about the red l-e-d power light beneath the screen, that is the power off light. If that red light light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply.
Oct 22, 2008 | Proscan 19LA25Q 19 in. LCD Television
Please Help!! Black Screen, Red Light Flashing
is this a plasma or a dlp tv? if is a dlp a have bad news for you get rid of the tv, if is a plasma then is something different, post the model # anyway to see if we can help you.
caypianan@yahoo.com
Aug 24, 2008 | Samsung FPT5084 50 in. Plasma HDTV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Advent HT3061A TV Logo
23 people viewed this question
Top Advent Televison & Video Experts
Are you an Advent Televison and Video Expert? Answer questions, earn points and help others
