Question about Briggs & Stratton Garden
Where would I find availability of parts in QLD Australia to suit a pressure cleaner 3200 psi coupled to a Briggs & Stratton motor pressure washer number 020225-0 part required chemical injection kit FIG E on general assembly part number 192914GS
    Novelist:
  • 97 Answers
Wayne,
Any Pressure Washer dealer should be able to sell you what is called a "Down Stream Injector". What you need to know is the flow rate. Like, at low pressure, see how many Gallons/Liters Per Minute actually comes out the wand. That is what the seller needs to know in order to sell you one the proper sized internal orifice. Also, you need to know that these devices only **** chemical at low pressure. They make special tips and/or wands so you can easily revert to low pressure to apply your cleaning chemical. This stuff is generic. It will come with standard pipe threading. Close is good enough on "flow-rate". Just use a bucket or something and get a reasonably close estimate.
Posted on Feb 29, 2012
  • 313 Answers
SOURCE: dayton 5000 psi pressure washer
check out www.smallengineadvisor.com for trouble shooting & repair.
Posted on Jun 24, 2008
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Posted on Jan 30, 2010
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Posted on Apr 23, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
SOURCE: Looking for manual for a briggs and stratton 2700
Gas pours out when I turn the dial from off to gas
Posted on Oct 07, 2010
On my brute 2500 psi pressure washer when I let go of the trigger it kills the motor. I changed the unloader valve and still does it . Any suggestions? Thanks
Excessive pressure can stall out a motor. Try reducing by adjusting unloader valve. Clockwise turn will increase pressure, counter clockwise turn will reduce.
Oct 30, 2016 | Garden
Why is oil leaking from air cleaner?
this is usually due to an oil overfill situation. You most likely added the full quart of oil into the crankcase on setting it up without checking the actual oil level periodically as you fill it. Recheck and drain out the excess as needed.
Jul 14, 2014 | Briggs & Stratton 020324 3700 PSI Pro...
What can you use as an extention hose with the original hose?
anything that has the same I.D. (inside diameter) as the original. Do NOT use a 1/4" I.D. hose on anything over 3200 PSI and don't use a 3/8" I.D. on a unit that uses a 1/4" I.D. hose because it will cause a pressure malfunction. Also make sure they have the same mate threads such as 22mm or whichever.
Jul 02, 2014 | Craftsman 2500 PSI Briggs & Stratton...
Oil type 2400psi
any hosue holdcar motor oil will work
Dec 31, 2013 | Briggs & Stratton 3000 PSI Pressure Washer
Problem with Briggs & Stratton 2400 PSI 190cc Gas Powered Pressur pressure washer, it locks up
Try disconnecting the pressure hose and work backwards after that like remove the unloader valve and so on. Contact Flowjet cleaning equipment for help over the phone.
Dec 03, 2012 | Briggs & Stratton Measuring Tools &...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
May 23, 2010 | Briggs & Stratton Briggs Stratton 2000...
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
Garden Logo
100 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
