Question about Cameras
When I plug my sanyo e1600 tp into a usb port, it won't turn on. It still won't turn on when I unplug it, unless I remove and replace the battery. I can review photos on the touch screen, bu
All in question above. The camera just stops working when I plug into USB port to download. Can't get photos onto computer.
Camera won't turn on when plugged into Mac to download photos.
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Feb 22, 2012 | Cameras
I get the blue screen with MSDC on it, it doesn't turn on unless plugged into the wall/electronic device, it wont turn off after I get the blue screen unless I unplug it, and it's been chargin
It is charging by USB port using ac adapter, can also charge by computer USB port during picture uploads and downloads. Do you need an instruction manual.
Feb 17, 2012 | Vivitar ViviCam 8025 Digital Camera
Netgear wna 3100 won't install on my windows xp. I have uninstalled it 3 times. It won't recognize the adapter. Then it does. Then in the end it won't recognize it even though it's there...
My adapter constantly loses connection completely to the router and cannont be re connected unless i unplug and replug back in the USB port. What a joke!?
May 06, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Require usb cable for sanyo vpc-t700 camera
Have you considered NOT connecting your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Even if you have to buy a card reader, it won't be any more expensive than a USB cable.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 03, 2011 | Sanyo Xacti VPC-T700 Digital Camera
"micro" usb port needs to be replaced
Consider NOT using the USB port.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Dec 31, 2010 | Nikon DSLR D90 Digital Camera
I have recently purchased a replacement usb cable that connects to my kodak easyshare m753 camera. I plugged the cable into the camera and into the front usb port on my computer. However, i cannot get the...
Sep 17, 2010 | Kodak Easyshare M753 Digital Camera
When I plug in the M407 camera nothing happens
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 15, 2009 | HP Photosmart M407 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
