Question about Onkyo Audio Players & Recorders
I just purchased an onkyo 5.1 S34000 home theater system. The reciever will not stay on. Turn it on, it turns off. Why is it doing this? :(
    Top Expert:
  • Onkyo Master
  • 75,581 Answers
Hello
Coneect it to AC power, without connecting any inputs or outputs connectons. That is, switch the set idle. Even it show this fault, make sure that the audio output section has short circuted components with it. Actually the repair job is very complicated, and skilled one.
If the set is new, and is in warranty period, get this set repaired by it authorised service center at your town. Otherwise, you have to spend for its repair, which is unpredictable now. OK.
Posted on Feb 22, 2012
djhack
SOURCE: Onkyo TX-SV525 on and off
Look under the wide ribbon cable going to the front panel. There is a cluster of components on the main board that make 12V and 6V power for different things. There is a pair of 12 ohm and a 1 ohm resistor. These run very hot and over time will take out the motherboard underneath. If these resistors disconnect the unit will cycle on and off rapidly. I found this out when I was replacing the resistors and repairing the circuit board.
DJ...
Posted on Oct 18, 2007
bluenadas
  • 203 Answers
SOURCE: onkyo home theater
You have a blown amp or you have DC on your amps....
Repair center is your best option....
Posted on Nov 19, 2007
petraman7
  • 1175 Answers
SOURCE: How to set factory codes for remote
Have you tried the Onkyo website yet?
Posted on Mar 18, 2008
tech48
  • 624 Answers
SOURCE: The Kenwood VR517 home theater
If this unit stays on for 5 minutes, and it appears to be playing normal, a bad speaker could be the cause unless you are using speakers that are not compatible with this unit.
The specs on this unit are 100 watts per channel and require 8 ohm speakers. if you are using speakers that are 6 ohms or 4 ohms, you will overheat the unit quickly and it will shut down. It is not designed to use anything less than 4 ohm speakers.
If you are using the speakers this unit came with, or you know that the speakers are 8 ohms (it should be listed on the speaker where the wires plug in), go ahead to the next step.
The first thing to do is to unplug one speaker, it does not matter which one, just pick one to unplug from the back of the receiver or right at the speaker. If you unplug one right at the speaker, make sure that the speaker wires do not touch together or touch anything else, they must be insulated from anything metal or conductive.
After one speaker is unplugged, turn the unit back on and let it play normally the way it was when it shut down after five minutes. If the unit continues to play for a long time, at least 30 minutes or more and does not shut down on its own, you have just found the culprit causing your problem. Some speakers may sound like they are OK, but still can cause a problem.
If the unit shuts down again after five minutes like before, go ahead and plug that speaker back in and do the same thing with one of the other speakers.
Continue this process until you have isolated one speaker as being the problem.
If you go thru the entire process and it still shuts down, you may have an internal amplifier problem. It can be something as simple as some heat stressed solder joints that need to be reflowed, or it could be a bad amp IC. This unit uses 3 different amp IC's and it could be any one of them or a component in the amp circuit. Sometimes it can even be a power supply failure. In any case, if the above steps do not work, you need to take it in and be serviced. There are no other end user options to perform.
I hope this helps with your problem, if you need more help just ask.
Posted on Jun 21, 2008
SOURCE: need codes for universal electronics remote that will oporate tx-sr606receiver
I have the same problem and from what I've read elsewhere there is not a cheap and easy solution. From what I gather, simple remotes (like what you get w/ your set top box) that use manufacturer's codes for programming treat "on" and "off" as a simple toggle. That means they fire out a singal signal which is supposed to simply change the state of the device from off to on or vice versa. The Onkyo apparently uses different signals for on and off. Because of this we will need to get a "learning remote" which can be programmed to provide a separate signal for any desired function. These tend to be much more expensive which is why they don't just give them out with your set top box. Right now I'm still fiddling with separate remotes until I break down and drop the bucks for the special remote.
Posted on Jun 03, 2009
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo TX-SR501 Receiver
At Houston Where can I buy Complete Home Theater Packages on Affordable price?
HI, please check out BestBuy for Onkyo home theater systems. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
Fix onkyo ts-sr313 turn on problem
If the relay clicks on and then off straight away then it might have detected an overload condition and so shuts down. Overloads can be caused by faulty speakers or wiring. But if the damage is done already then one of the main power amp transistors or other devices could be short circuited.
Oct 16, 2014 | Onkyo TX-SR313 Home Theater Receiver - 5.1...
Inquiring about a new remote control for home theater system.
The Harmony universal remote is on clearance at my local Radio shack for $37. Normally $100. Great remote.
Jun 26, 2009 | Audio Players & Recorders
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Rca home theater system reciever makes noise when turn on
is it a humming noise, or a high pitch noise, and is coming from the speakers or the receiver?
Jul 21, 2008 | Audio Players & Recorders
Hook up
I'd connect the dish network receiver to the TV's "in" ports and then use an RCA cable to connect the TV's out ports to the onkyo home theater's in ports. It should look something like this:
DVR out -> in Sanyo 42", Sanyo 42" out -> Home theater in
Make sure you don't accidentally plug the cable into the out instead of the in as then you won't be able to hear (and possibly see) anything.
Jan 06, 2008 | Televison & Video
29 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
