Question about Sony 3-WAY 6X9 SPEAKERS Car Speaker
How to install a xm3 crossover - Sony 3-WAY 6X9 SPEAKERS Car Speaker
Pantech crossover wont connect to computer
so thats your problem = need drivers.Or maybe wrong cable? Try installing drivers without the phone connected,or possibly anything else.
Mar 02, 2014 | Pantech Crossover
Tip
Clarion EQS750 Equalizer Manual Download
Download Clarion EQS750 Equalizer / Crossover Manual
Have you misplaced your Clarion EQS750 Equalizer / Crossover Installation Manual?
Would you like a digital, searchable, pdf version of the Clarion EQS750 Equalizer / Crossover Installation Guide?
Follow this link
to download a pdf version of this manual.
I hope that helps.
__________________________________________
on May 03, 2010 | Car Audio & Video
Tip
Clarion EQS750 Manual Download
Follow this link
I hope that helps.
Hot water at showers is intermitent while shower is on
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/Crossover.html
Set timer so pump is off when shower time arrives
Check for crossover
Check if installation is correct... is the crossover valve installed correctly?
Gene
Feb 02, 2012 | Grundfos Comfort System Recirculator ...
My husband and I are trying to get to our thermostat to change in my 2002 rendezvous, but there is a metal pipe in the way that we can't figure out how to remove. just behind the pipe, is a metal plate...
Hello vocalviixen,
The pipe that you referred to is the exhaust crossover pipe. Below I've included removal and installation instructions.
Also, the procedure for bleeding the coolant system is critical; if you need those instructions please post the question.
REMOVAL PROCEDURE
1. Disconnect the battery ground (negative) cable.
2. Remove the throttle body air inlet duct.
3. Drain the coolant from the cooling system.
4. Remove the inlet radiator hose from the engine.
5. Remove the thermostat bypass pipe.
6. Remove the exhaust crossover heat shield bolts.
7. Remove the exhaust crossover heat shield.
8. Remove the exhaust crossover pipe studs/nuts.
9. Remove the exhaust crossover pipe.
INSTALLATION PROCEDURE
1. Install the exhaust crossover pipe.
2. Install the exhaust crossover pipe studs/nuts.
3. Tighten the exhaust crossover pipe studs/nuts to 18 lb ft.
4. Install the exhaust crossover heat shield.
5. Install the exhaust crossover heat shield bolts.
6. Tighten the exhaust crossover heat shield bolts to 89 lb in.
7. Install the thermostat bypass pipe.
8. Install the inlet radiator hose to the engine.
9. Fill the cooling system with engine coolant.
10. Install the throttle body air inlet duct.
11. Connect the battery ground (negative) cable.
Regards,
netvan
Mar 14, 2011 | 2002 Buick Rendezvous
Display only blinks, how to reset the unit?
hey there michael_wick,
you need to install version 1.68 first before the 2.14 unless you have that installed already.
why cant you update it via the USB cable to your computer...all magellan GPS require at least Windows OS XP service pack 2 to sync with the computer.
if your not seeing the crossover listed in your computer, can you see the usb connection wizard in the lower left of the task bar on your computer.
btw, is this a true crossover, or a 2200T thats been upgrated with the crossover firmware?
Bill
Standing Member of G.O.T.
PLEASE SUPPORT OUR TROOPS
Oct 12, 2010 | Magellan Crossover GPS
Need a picture of a water pump housing for a 1998 eldorado
Water Pump Removal and Installation All Engines To Remove:
  1. Before servicing the vehicle, refer to the Cautions and Warnings in the beginning of this section.
  2. Remove or disconnect the following:
    • Coolant into a suitable container
    • Upper filler panel
    • Air cleaner assembly
    • Secondary AIR injection control valve gm_car_cad_sev_wtr_pmp_belt_shld.gif
    • Oil level indicator tube nut
    • Water pump belt shield fasteners
    • Radiator outlet hose from the thermostat housing gm_car_cad_sev_wtr_pmp_and_covr.gif
    • Water pump cover bolts
    • Water pump cover
    • Heater return hose
  3. Position suitable water pump puller/installer tool (or special service tool J38816-A) to the water pump locking ears.
  4. Fasten the support plate to the water housing crossover to ensure proper engagement of the tool to the water pump locking ears.
  5. Remove or disconnect the following:
    • Pump from the housing:
      1. Use suitable water pump puller/installer tool (or special service tool J38816-A) to turn the pump clockwise
    • Support plate from the water housing crossover gm_car_cad_sev_wtr_pmp_rem.gif
    • Water pump
    • Seal from the water crossover
  6. Clean the sealing surfaces of the water housing crossover and the pump cover.
  7. Clean and inspect the water pump.
To Install:
  1. Install or connect the following:
    • Seal into the recessed portion of the water crossover
    NOTE: The notched locking ear must be in the 7 o'clock position.
  2. Index the water pumps locking ears with the tangs in the water crossover.
  5. Turn suitable water pump puller/installer tool (or special service tool J38816-A) counterclockwise.
  6. Torque the water pump
    • Torque to: 74 ft. lbs. (100 Nm)
  7. Remove the support plate from the water housing crossover.
  8. Install or connect the following:
    • Water pump cover to the heater return hose
    • Water pump cover to the water housing crossover
      1. Torque to 89 inch. lbs. (10 Nm)
    • Radiator outlet hose to the thermostat housing
    • Water pump drive belt
  9. Place the water pump belt shield in position.
  10. Install or connect the following:
  11. Fill the cooling system.
  12. Start the engine then idle until normal operating temperature is attained.
  13. Recheck coolant level and top off as needed.
  14. Test drive the vehicle.
Aug 17, 2010 | 1998 Cadillac Eldorado
How do i change a 2004 Lincoln LS fuel pump?
Hi. here's how to change the fuel pump. The actual electric fuel pump is in the tank on the right side. The tank is directly below the rear seat. If you remove the seat bottom you will find a 6 inch or so cover. Under the cover there is a plastic, threaded collar that locks the fuel pump into the tank. The driver's side also has a pump, but it works only my venturi effect from the electric pump on the other side. This pump is used to equalize the fuel level from left to right. The drive shaft tunnel prevents all but the very top of the tank from communicating left to right.
Aug 12, 2010 | 2004 Lincoln LS
Broken powerboard for Xerox XM3-19W monitor
Well you might be able to find one in a scrap monitor on an auction site, or put in the model number on google. Im always after parts for monitors and it gets annoying when you cannot find any lol.
Mar 30, 2009 | Computers & Internet
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
Sony 3-WAY 6X9 SPEAKERS Car Speaker Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
