Question about Health & Beauty
Need users manual for Oster dog clipper model 44-01B
  • 6 Answers
SOURCE: Clippers jam and won't cut when trying to use attachments
I know it sounds simple, but have you tried a good sharpening.
Posted on Aug 15, 2009
SOURCE: NEED PARTS FOR OLDER OSTER CLIPPERS
I gave it a shot and it worked!!!....
No need to bother with the universal guards. They looked bulky for the task, and after careful (visible scrutiny) decided to gamble on the "fast feed clipper" guides. Check them out here:
http://www.cache-beauty.com/oster0541.html
There are surely other people who sell them - you might shop around, but I bought from these guys. Warning, the shipping price is kinda steep. But like I said in my last post, I've tried other clippers and these are just the best. It was worth it to me.
Anyway, I am now confirming that these guards fit this old clipper brand of ours. Perfectly!
Posted on Feb 03, 2009
SOURCE: Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: I have an old Oster adjustable dog trimmer model
YES! YOU NEED TO BUY A NEW BLADE OTHER WISE IT GOIN A PULL THE HAIR
Posted on Jun 27, 2009
philschneide
  • 448 Answers
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Posted on Oct 03, 2009
Oster blade no. 913-50
http://www.ebay.com/itm/Oster-Blade-Set-913-50-Fits-Fast-Feed-17-tooth-76913-506-New-/130803957423
Mar 09, 2014 | Oster Corporation Pet Oster Performance...
Oster clipper
It sounds like a faulty motor if they are under a year old send then back who you purchased them from otherwise it could be a costly repair.
Dog Clippers
Jan 15, 2013 | Oster Grooming Golden A5 2 Speed Clipper &...
How do i oil and clean my oster clipmaster clippers
Please see user manual for this information. If you no longer have your user manual, please see link below
http://www.osterpro.com/Manuals/MANUALS/101_UnivMotorManual.pdf
Oct 23, 2011 | Oster Golden A5 2-Speed Universal Motor...
Difficulty shaving Spanish Water Dog
The biggest issue with clipping animals (except sheep which use completely different clippers) is that once you have sharpened blades, you need to go slow and keep then blades oiled and cooled. The KOOL spray by oster works great and the clippers you are using are a good reliable brand and model. When clipping my cocker/schnauzer cross, I have a 1/2 inch guard on it (have to use a 30 or 40 blade with the guards) and it takes about an hour. I stop every 10 minutes or so to let them cool down, spray and oil them.
May 30, 2010 | Oster 76076-010 Hair Trimmer
I have an Oster dog clipper Model 103582-010-000 and would like to know what blades I can use, also where I can get an owners manual. Thanks, Dan
Blades are available online at
Oster
800-887-6682
OR
CacheBeauty.com
But once the plastic clip that mounts the blade to the unit brakes you are screwed. Oster can't supply that anymore. You can always sharpen the blades and make sure you keep them lubricated going forward. Google sharpening clipper blades to find instructions.
Steve O. Minneapolis, MN
May 19, 2010 | Oster 76076-010 Hair Trimmer
Blades fell off oster dog clippers but can't fit them back on. Please help !!
With the hinge of the clipper facing you:
Make sure hinge is open, if it is not, prize it open with a flat head screwdriver.
Slide the blade on with the blade siz/number faceing you.
Snap shut.
If this fails, try again, but push the latch in as you snap them shut.
If this fails, you may need repair!
www.sheareaseltd.com
May 15, 2010 | Oster Golden A5 2-Speed Universal Motor...
My electric dog clippers don't cut well
if the problem arrears to be with one blade on several clippers it sounds like you need to send the clipper blades for sharpening.
Aug 15, 2009 | Oster Health & Beauty
Changing Blades
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Health & Beauty Logo
605 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
