Question about ASUSTeK M2A-VM HDMI Desktop Board - Athlon 64, Athlon 64 FX, Athlon 64 X2 Dual-core, Sempron - nVIDI... Motherboard
How to install a cpu fan
Auto shutdown is the problem
Why does my Samsung rv520 shut down after 30 min
Overheating? Are the airways clear and is the fan clear?
Feb 28, 2015 | Samsung RV520 Laptop
COMPUTER SHUTS OFF
There are several reasons for Auto shutdown of the PC, it can shutdown due to CPU processor overheating, Hardware conflict, SMPS voltage supply issue. what ever may be the reason, if you have knowledge of assembling then you can try below steps
1. Open the cpu cabinet and remove the heatsink then clean it.
2. clean the CPU Fan (use some spray like WD40)
3. Remove the old heat sink paste from the processor and apply heatsink paste and refix all the hardware.
4. check the voltage supply of the SMPS (power supply unit)
otherwise you can call computer hardware engineer and get the problem fixed.
Apr 18, 2014 | ASUS M11AA-US002S Multimedia Desktop PC
Automatic shutdown
Check the CPU Fan and make certain it is functional. Some computers do an auto-shutdown when the CPU reaches a certain heat ratio upon starting. Make sure the power conncetion is on firmly.
Jan 13, 2014 | HP Computers & Internet
Always shutdown"CPU Shutdown Temperature
Hello download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=1093
Check the bios for any cpu overclocking settings
and set it back to standard settings.
Renew also the thermal cooling paste between the cpu and the cooling fan.
See if the cpu fan is running when the pc starts.
Be VERY carefull when you remove the cpu cooling fan
and take care not to damage the cpu.
And take antistatic precautions when you work on the mainboard.
If you have not tryed this before let a expert do the job.
Hope this will help you
Nov 22, 2012 | EliteGroup Computer Systems Ecs...
Fans still running after shutdown
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Aug 18, 2012 | OCZ Technology PPC Silencer 500W MKII...
Why do my laptop cannot be turn on. It automatically shutdown by itself even if in full battery?
Reasons might be:
First, there is a problem on your Operating System/
Situation: If its auto shutdown upon booting or upon loading windows/
**solution:Repair/Reformat the OS used/
Second, there might be a problem in you Memory Card/
**solution: Try to clean your Memory Card using an Eraser/
Third, make sure that you placed your laptop on a clean and cool area/let the air on the fan flow/most probably your CPU fan might be affected for that and leads you to auto shutdown/
**solution: clean the cooling fan,
Nov 25, 2010 | Computers & Internet
Computer shuts down by itself
There can be many reasons of unexpected shut down of your system.Below are some remedies to solve it
Run an anti-spy ware and anti-virus utility to make sure that the shutdowns aren't being caused by a malicious program. If the shutdowns are infrequent, install a CPU temperature monitor utility to keep track of the CPU's temperature. If the CPU is overheating, or the shutdowns are frequent, then you will need to troubleshoot your computer's internal components.
Check any recently installed internal components to ensure that they are properly connected to the computer's motherboard. Make sure any new expansion cards or memory modules are securely seated in their slots, and ensure that the power and data cables are properly connected to any new drives.
Check for large dust buildups on your CPU fan. If the fan isn't effectively cooling your CPU, the overheating CPU will cause your computer to power off. Carefully pick away large pieces of dust with your fingers, and then spray the CPU fan with a can of compressed air to remove the rest of the dust.
Reapply the heat sink compound between the CPU and heat sink if the computer continues to turn off unexpectedly. Heat sink compound is a pasty substance that fills the space between the heat sink and processor, which increases the heat sink's ability to absorb heat from the CPU. But worn heat sink compound won't properly redirect heat away from the CPU. Power down your computer, disconnect its power cables and open the case. Unplug the CPU fan's power cable from the motherboard, remove the heat sink and fan combination from the CPU, and then apply the heat sink compound to the CPU--refer to your product manuals for details on reapplying heat sink compound.
Thanks .
Have a great day.
Oct 03, 2010 | Dell Inspiron 537s PC Desktop
When turn on my computer after a seconds the system is shutting down.. i don't know what to do, is there a problem with the processor?
A overheating CPU will shutdown and won't start up again until the CPU has cooled down.
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Computers & Internet
I have a custom built computer w/ xp pro. my computer shuts its self off. why? sometimes it will do it 4-5 x a day, then there are days it won't do it at all. any suggestions?
Automatic shutdown can be due to mostly over-heating of the CPU or CPU fan not working properly. Blow the CPU areas plus the CPU fan with an Air-blower and check if the CPU fan is working properly or not. If the CPU fan is malfunctioning then replace it. Your system will work fine.
Make sure your system is free from virus and worms as it too can be the cause of  system shutdown (but this cases are very very rare).
That's it.
Mar 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
Auto shutdown
Usually this problem is caused by a thermal [overheating] condition. Best solution is to open the case and see if the cpu fan is working. If not replace with a new heatsink fan combo and make sure you use a quality thermal grease between the cpu & heatsink. Hope this helps & please rate this solution as fixya. Thanks.
Feb 03, 2009 | HP Pavilion Desktop PC
ASUSTeK M2A-VM HDMI Desktop Board - Athlon 64, Athlon 64 FX, Athlon 64 X2 Dual-core, Sempron - nVIDI... Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
