Question about Onkyo Audio Players & Recorders
What would make a reciever not want to turn on and stay on?
    Top Expert:
  • Onkyo Master
  • 74,136 Answers
Hello
So many reasons have to point out for this fault. as the power indicator stays ON, the power supply section will be almost OK, but if some auxillary power outputs are absend this may happen. If any of audio output sections have shorted component/s with it, this may happen.
To point out the exact fault location, the details you have given here is not succiciant. OK.
Posted on Feb 22, 2012
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
Shoukd the mouse be turned off after I use it? Why doesnt the light stay on?
it is recomended to turn of the mouse after use else the battery will drain, the light will not stay on as it has sensors to detect the movement which signals the reciever attached to the system & will work when the mouse is moved
Jun 05, 2010 | Logitech Cordless Mouse
Acer monitor won't stay on
Check the power connection, make sure VGA/DVI pins are not damaged and securely fastened. Monitors which do not recieve steady data through wire will sleep so unless it is recieving data it will turn off.
Jan 03, 2010 | Acer AL1715 17" LCD Monitor
When reciever is turned on it shut's right back off. It will not stay on. Also it would loose volume. Why is this and can it be repaired?
this is a main power issue and the only way to fix it is to replace the main board which is the heart of the reciever . costly exercise . sorry to hear that
Sep 27, 2009 | Harman Kardon AVR 510 Receiver
Sony amplifier STR DA2000ES protector code 22
go to your manual and repeat connection and setup and try with new cables because may be the cat bite something hidden from your eyes.
Apr 10, 2009 | Audio Players & Recorders
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Will not stay on 11 meter turn it off comes back on 10&12 meter will not transmit am or ssb recieve ok. rci 2995dx.
Hello janetsue, If this radio has the blue or green screen LCD face then this is a default that is built into the radio. It depends on how the radio was "converted" when it was bought new.
It will not key up on 10 or 12 because of the default. A little more info supplied would be real helpful,,,, Let me know, Mechanic
Nov 01, 2008 | Ranger RCI-2995DX Base Scanner
Reciever won't stay on
Do you have too much of a load on the amplifier? Or as SallieJohns mentioned, is it getting adequate ventilation?
Apr 02, 2008 | JVC RX-6018V Receiver
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
